tuga
Hi-Fi News measures both speakers and reports on the pair matching accuracy:
My little Dali Zensor 1s sitting in my speaker wall have L and R suffixes on their respective serial numbers.
I think I've seen speaker pairs with the same serial number on both speakers but I can't recall which.
Sorry, I guess I misunderstood - when you talked about matching pairs, that is for frequency response, which is how I responded. Quite a few companies do that.Sorry - should have said quality of the imaging. Obviously any left/right bias would follow the speaker, if they were not level matched.
My fundamental point above. The speakers are sold with left right markings, and the instructions are to place them as marked for the best imaging. The reason for that cannot be frequency response. It would only make sense if there was a mirrored asymmetric left right radiation pattern (Which could result from non aligned mechanics as shown in some of the examples above, or (eg) a side facing tweeter). However the Oberons, at least visually, are mechanically symmetric.
I suspect the real reason is internal to Dali - such as tracking speakers through the production process, or managing after sales service etc. Or perhaps they use it for grain matching on the higher end speakrs, and is then used for the entry level vinyl wrapped models for process consistency.
No apology needed - my OP wasn't as clear as it should have been.Sorry, I guess I misunderstood - when you talked about matching pairs, that is for frequency response, which is how I responded. Quite a few companies do that.
Speakers marked as being specific to left and right is something else. I don't know why that would be necessary.
What specifically does it say? Your quote above only talks about them being a matched pair.
In order to create the best possible stereo image, DALI loudspeakers are designed in matching pairs. Left and Right are clearly marked on both packings and the rear of the loudspeakers.
Place the Left and Right speakers to the left and right as seen from the listening position.
That is still FR or perhaps you mean overall gain - left and right positioning is irrelevant for that.
