For an outdoor space under a roof. With 12' high ceiling. 50' by 20' with a wall on one 50' side; the other three sides are open except for large supports. can eight speakers permit a fairly uniform stereo signal throughout the space. A constraint is the speakers must be mounted on the ceiling perimeter. A non constraint is frequencies below the drivers roll offs as a large subwoofer wiill be a part of the project Amplifiers levels can be used to split the two sets of four speaker volume. Amplifier power is nominally 200 watts per channel into the the four ohm load exhibited by the 2 speakers per channel in parallel Power is gobs. The speakers lowest roll off frequency is below the range of the frequency of the male human voice.
If you feel stereo is a pipe dream, where would you mount the transducers for mono.
Your thoughtful consideration is appreciated.
