HarmonicTHD
- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,838
No the R11 will be fine at 3m. (I heard the Reference 5 at about that distance and it was fine).Hi David. It was under the impression that the optimal size of a speaker would not only depend on the listening distance but also on the room size.
I have been on the lookout for upgrading my old KEF R3 in a 2.1 setup to a new 5.1 KEF R surround setup, where I will be using the R3 as surround speakers. The room is big, 6 x 8 x 2.7 meters, and openly connected to areas with about the same volume jointly. However, as I sit around 2.6 meters away from the speakers, I am in doubt if I should go for the R7 or R11 to go with the R6. Ideally, I would not like to compromise on the stereo image, but at the same time, I also want the speakers to sound full and project a big wall of sound. On the other hand, I would rarely go past 80 db in average listening level. Would I be shooting myself in the foot by going for the R11 as I sit less than 3 meters away?
But either way, get at least two subs for that room size of yours, because you will need it to „pressurize“ it and secondly to even out the inevitable room modes. And remember according to the Harman preference studies, that bass makes up ca 30% of the overall preference. (So if you want it to sound full, what ever that means exactly, don’t skimp on bass).
