I'm doing the same thing right now. Slowly building my next cinema room with a floating wall/ceiling. I've removed all power, wires, pipes etc behind the wall to be surface mounted within large trunking etc.So back to my question... how do you build the wall/ceiling to not ruin the speaker? Resilient channel is not rated to support the load of a normal speaker, especially in the ceiling, and this is not a normal speaker. It weighs twice as much as the rest of their architectural line..
..But for the surround and rear speakers, I'm going to build surface mounted full wall height boxes, so as not to cut into the walls. Then suspend them a little and rest them with some kind of rubber backs so as to help with decoupling them from the walls too.
Now if you have to cut into the walls, I would have build large back boxes to help with the recommended box volume.
Good luck with yours!
