- Joined
- Nov 19, 2018
- Messages
- 108
- Likes
- 227
Could be those woofers used there have bit huge or over avarage L(e) value compared to other builds without that raising distortion into XO region, or L(e) value of used tweeter is exstreme low.
There's something to this theory, given where and how the distortion is showing up (single tone sweep, high in the woofer's response). Nguyen made special mention of having developed a new shorting ring configuration for the woofers, which offers some clues - it's possible the initial driver design showed high HD in high frequencies, and they inductively determined (pun intended) that a high dLe(i)/dx was the primary culprit (hence the addition, or improvement, of the shorting ring). Or maybe, given that this is a relatively high-excursion driver with a beefy voice coil, they made tweaks to minimize IMD from a potentially high dLe(x)/dx that resulted in higher HD from current-related inductance modulation, which was only partially offset by the improved shorting ring ...
Horses for courses, as they say.
