Jack Harrison
- Joined
- Mar 1, 2023
- Messages
- 73
- Likes
- 102
Yes, see screenshot:Are you sure? AFAIK Moode only supports Airplay 1.
Indeed, I just checked too. Unfortunately I don't use Apple devices myself so won't work for me, but would be useful for guests.Yes, see screenshot:View attachment 305781
“Community“ fan, or from the British Isles?The Moode interface is streets ahead of …
Did you solve that? I have identical problemSadly my Moode experience was even worse than Volumio
Just tried it on my Pi4. It did not enable AP after first boot so I have to went outside and purchase an ethernet cable to connect it to my router in order to have it configured.
Once I did that, it simply does not even allow me to configure WiFi SSID to connect. The moment I hit save, the whole setting just froze and I won't be able to enter any setting pages anymore
I did resolve this later.Did you solve that? I have identical problem
I want to use Airplay (1) not Airplay 2. Do you know if that's an option?I'm currently using a Raspberry Pi (3B+ and 4B) and i prefer it with the 4B - it's so great, that it's almost hard to believe that it's free - it even has airplay2?
I've heard of other options, but they seem a bit more complicated and I'm not sure that they offer the same options as the most mainstream option.
Let me know which OS you think is good and why.
BTW my current set up is a Raspberry Pi 4B, Topping D10S, and a Fosi Audio BT20A-S.
Sorry for the late response, but I thought you'd like to know that the latest firmware for the WiiM Pro and Pro Plus includes native support for LMS/Squeezebox. No more DLNA!If already you’ve got Wiim Mini’s or Pro’s around your house, you can’t go wrong either way and LMS is a fun thing to set up and play with. If you’re starting with a bunch of RPi’s, LMS is in my opinion the best choice.
Just updated my mini to a pro (used direct from Wiims eBay for $100) specifically for native LMS!Sorry for the late response, but I thought you'd like to know that the latest firmware for the WiiM Pro and Pro Plus includes native support for LMS/Squeezebox. No more DLNA!
In that case a Pi + ROPIEEXL is pretty good shareware.I want to use Airplay (1) not Airplay 2. Do you know if that's an option?
Qobuz playlists work the other way around, as you can see below (Roon screenshot). Does Spotify? I don’t use Spotify.I use LMS, installed on my NAS. The user interface is not modern, but it is functional. It has been extremely stable and uses little in terms of CPU and RAM resources.
The Spotify and Tidal plugins work. My chief annoyance is that any tracks I add only store to a playlist in LMS. So, for example, if I want to add a track in Spotify that I can access from my car, I need to do so in the stand alone Spotify app. Roon had the same issue when I tried it.
You might like the Material Skin plugin:The user interface is not modern
I am using Material Skin.You might like the Material Skin plugin:
LMS > Settings > Plugins > 3rd party plugins > Material Skin
