Think I agree. I wouldn't know where to start, so I tweak existing or at the very least look to the measurements for excessive dips and peaks to counter with EQ. Never blind.I don't think there's much merit in EQ'ing headphones or speaker systems unless the EQ profiles have been created with some kind of measurement system to a known curve. EQ'ing to taste 'randomly' is a voyage into subjectivity....I believe in EQ'ing to a known measured curve using for example Oratory's measured EQ's for each brand of headphone and then (perhaps) EQ'ing a little to taste from there....but I think EQ'ing without any kind of measurement involved is a bit of a folly and exercise into subjectivity. Same goes for EQ'ing speaker systems to rooms. So if people are just posting 'random' EQ's they've created for headphones in this thread that are just based purely on their own subjectivity (which seems to be happening recently), I don't think there's a lot of merit in that.
Ah, I thought you were doing it blind. Ok then. Maybe make it clear where you got it from & how you changed it & why.Think I agree. I wouldn't know where to start, so I tweak existing or at the very least look to the measurements for excessive dips and peaks to counter with EQ. Never blind.
I did for the hd800 above, if I remembered correctly. No idea for the w5000. But point taken.Ah, I thought you were doing it blind. Ok then. Maybe make it clear where you got it from & how you changed it & why.
I don't think there's much merit in EQ'ing headphones or speaker systems unless the EQ profiles have been created with some kind of measurement system to a known curve. EQ'ing to taste 'randomly' is a voyage into subjectivity....I believe in EQ'ing to a known measured curve using for example Oratory's measured EQ's for each brand of headphone and then (perhaps) EQ'ing a little to taste from there....but I think EQ'ing without any kind of measurement involved is a bit of a folly and exercise into subjectivity. Same goes for EQ'ing speaker systems to rooms if there is no measurement involved. So if people are just posting 'random' EQ's they've created for headphones in this thread that are just based purely on their own subjectivity (which seems to be happening recently), I don't think there's a lot of merit in that.
I think what you're describing there is in contrast to what this whole site is about - measurement and objectivity, backed up with a little bit of subjectivity, but 100% pure subjectivity with nothing to base it on is generally a bad move and at odds with the purpose of this site, so I wouldn't want to see this thread clogged up with lots of the latter.But as to your last point, I dont agree. If an EQ set sounds good to person A, regardless of source and science behind it, they are entitled to share and we are entitled to try. Just because its not based on measurements, doesnt mean it doesnt improve things. Subjectivity isnt a crime. Or invalid per se.
That's unfortunate for you then.I think what you're describing there is in contrast to what this whole site is about - measurement and objectivity, backed up with a little bit of subjectivity, but 100% pure subjectivity with nothing to base it on is generally a bad move and at odds with the purpose of this site, so I wouldn't want to see this thread clogged up with lots of the latter.
It is or it isn't, I'm just having my say, and I am the thread starter.That's unfortunate for you then.
No ill will here, and I've libated so apologies if this sounds antagonistic, but for the record, that's not how it works. Anyway, happy listening, EQ or otherwise.It is or it isn't, I'm just having my say, and I am the thread starter.
Well, we've both had our say, doesn't matter. Happy listening.No ill will here, and I've libated so apologies if this sounds antagonistic, but for the record, that's not how it works. Anyway, happy listening, EQ or otherwise.
You can start with the one by oratory: https://www.dropbox.com/s/s4isno09gt20ozf/Sennheiser HD660S.pdf?dl=0
If you're not happy with the result, I can make one for you based 3 other measurements.
https://www.0db.co.kr/index.php?mid=REVIEW_0DB&category=182&page=4&document_srl=211526What do you mean by that?
Disagree. Any EQ profile "standard" assumes perfect hearing, and the curve is ideal for such individuals (16 year olds without high frequency hearing loss). But those of us over 50 may require EQ simply because of hearing loss from age or damage. For me, there is no possible curve or standard that can possibly be used for my needs unless I apply some correction curve based on my hearing limitations (I assume such curves can be extrapolated from hearing tests?). We have no choice but to voyage into subjectivity...I don't think there's much merit in EQ'ing headphones or speaker systems unless the EQ profiles have been created with some kind of measurement system to a known curve. EQ'ing to taste 'randomly' is a voyage into subjectivity....I believe in EQ'ing to a known measured curve using for example Oratory's measured EQ's for each brand of headphone and then (perhaps) EQ'ing a little to taste from there....but I think EQ'ing without any kind of measurement involved is a bit of a folly and exercise into subjectivity. Same goes for EQ'ing speaker systems to rooms if there is no measurement involved. So if people are just posting 'random' EQ's they've created for headphones in this thread that are just based purely on their own subjectivity (which seems to be happening recently), I don't think there's a lot of merit in that.
Yeah, that's fine, but you're EQ'ing to some kind of understandable curve, your own curve that is related around your hearing loss, that's not random as I guess you know which frequencies you can hear and which you can't hear as good....describing how you achieved that in this thread would have merit in my eyes. It might not be useful for exact replication by someone else because they might not have the same kind of hearing damage, but it could be useful for them to understand your approach. Yes, so your EQ'ing would not be based entirely on subjectivity, it would be based on knowing what frequency areas you are deficient on, and then I guess you boost those areas. I suppose you could keep other areas of the curve as 'Harman Curve' or something and boost your problem frequencies around that. That's not the same as me having a go at someone for posting "random EQ's" that have been done purely on subjectivity with nothing else behind them.Disagree. Any EQ profile "standard" assumes perfect hearing, and the curve is ideal for such individuals (16 year olds without high frequency hearing loss). But those of us over 50 may require EQ simply because of hearing loss from age or damage. For me, there is no possible curve or standard that can possibly be used for my needs unless I apply some correction curve based on my hearing limitations (I assume such curves can be extrapolated from hearing tests?). We have no choice but to voyage into subjectivity...
Going to bed now. Will do it first thing in the morning tomorrow.Could you?
If you're listening to a recording of unamplified acoustic music - do you want it to sound like it would if the musicians were playing live in front of you?Disagree. Any EQ profile "standard" assumes perfect hearing, and the curve is ideal for such individuals (16 year olds without high frequency hearing loss). But those of us over 50 may require EQ simply because of hearing loss from age or damage. For me, there is no possible curve or standard that can possibly be used for my needs unless I apply some correction curve based on my hearing limitations (I assume such curves can be extrapolated from hearing tests?). We have no choice but to voyage into subjectivity...
