Offset is the leading and trailing nulls in the .wav format before and after the music data. It is not part of the music and it does not create any "dead" time in the music track. It is simply part of the format. Given this, it would follow that this should not impact sound quality in any way, unless there is something at work here we don't yet fully understand.
The following track downloads contain 4 tracks of piano, 2 being 16/44.1 and two being 24/96. Each of the pairs contains one unaltered track and one track with 200 nulls added to the offset.
https://www.dropbox.com/sh/g9jz9lwgvozepic/AADx1d8YLCr5YCPQl23fUkFDa?dl=0
Since this is not an A/B/X test, one can only rate each of the tracks for things like dryness, ringyness, attack, decay, warmth, depth or shallowness of soundstage, clarity, wooliness etc. If you listen to these tracks, please rate them 1-4 with 1 being the most live sounding and 4 the least. Each track should have a unique number assigned, for example:
1) track 2a
2) track 1
3) track 2
4) track 1a
Also, please list your playback software, DAC and any re-clocking/resampling that occurs in your system. This will help answer the question of whether this is a hardware or software anomaly. Whether you use S/PDIF, network or USB to connect to the DAC.
Everyone does not have to get the same result to make this a valuable exercise. Even if they don't, if there is a definite trend that demonstrates that the tracks sound different, this is useful too.
After about 2 weeks, I will post all of the results. We will see if there is any smoking gun here. This test is already ongoing on several other forums, so I will combine all of those results as well.
Thanks,
Steve N.
1) track 2a
2) track 1
3) track 2
4) track 1a
Thanks,
Steve N.
