If you are going with Berhinger the really cheap ones have only up to 48 khz recording which might not be an issue, but some also only do 16 bit which might also work, but 24 bit gives you a bit more to work with.
You might consider the Arturia MiniFuse 1 if you want to save a bit over the Focusrite Solo. They are $99. Available in black or white.
1-in/2-out USB-C Audio Interface (USB 2.0 Compatible) with 1 Mic/Line/Instrument Preamp, 250mA USB-A Hub, and Included Software Suite - Mac/PC
www.sweetwater.com
The Solo's are only $109, but to me the MiniFuse looks much cooler. Very important how cool it looks.
Performance of the MiniFuse and Solo are very similar across the board.
View all results for focusrite solo at Sweetwater — the world's leading music technology and instrument retailer!
www.sweetwater.com
Julian Krause does good youtube reviews with measurements.
