charlielaub
As part of an effort of mine to develop and characterize some new crossover filters, I am looking for input on music tracks that I can use to test for the audibility of group delays that arise from the crossover filters.
Once I gather up a few test tracks (these should be limited to 10-20 seconds) I will do the following:
1. apply a range of filters that can be used in loudspeaker crossovers. The audio is split into 2 identical copies. One is passed through the LP filter and another is passed through the HP filter. These two are then summed, to mimic the summation "in air" of a loudspeaker's 2 drivers using this crossover. This will be saved as the processed version of the test track for crossover XYZ.
2. I will post audio files on my web site and then ask people to listen to them and rate them. I am not exactly sure of the best way to present the choice, but perhaps like this:
Three tracks: unprocessed original audio, audio processed with crossover A having low group delay, audio processed with crossover B that has high(er) group delay.
The tester first listens to the unprocessed track as many times as they would like, then they listen to the two processed tracks and are asked to rate which sounds better/cleaner/whatever.
I collect these poll results and after some time (a month?) present the results.
If this testing format is not ideal, please suggest a better one.
The problem that I see is that the overachiever out there who wants to score 100% could download the audio and then do some analysis of the group delay profile, therefore "cheating" by obtaining the correct answer to the "test". I'm not sure this could be done with a music file or not, but if you know of a way to thwart this sort of cheating please let me know. It would be nice to get some honest results back.
One motivator for this sort of testing is that I have developed a new "family" of crossover filters that have a very steep transition band but limited maximum attenuation, which I created from elliptical filters via optimization to reduce group delay, improve LP+HP summation to reduce ripple, etc. These steeper filters do have group delay that is elevated, but I consulted the published literature in psycho-acoustics to see where the threshold of audibility lies, and made sure that the crossovers remained below those levels for all audio frequencies. Since there is a camp that elevates linear phase type filters, I would like to throw down this challenge to see if, with music signals, people can actually detect group delay peaking, etc. (phase distortion) and at what level. It can't be 100% scientific via this sort of approach, but would be at least some real data.
Please share your thoughts on this experiment and its deisgn. If someone has experience with these sorts of polls and how to set them up, I would love to hear about it.
Also, please suggest some tracks that might highlight group delay non-linearities. Supposedly our hearing is most sensitive to strong transients like click sounds and when using headphones. I want to focus more on music and not synthetic signals, nor something like only two drumsticks or woodblocks being hit together. At the other extreme, no mostly-continuous tones like organ music either. I could possibly present a few (3 or 4) different tracks for each test. Your input is appreciated.
