Doc Kerash
- Joined
- Jul 12, 2023
- Messages
- 2
- Likes
- 0
I'm looking for some inexpensive monitor speakers for mixing music that I write and perform, and a way to connect them to a sub.
I'm not really an audiophile and am mainly looking (I think) for fairly good sound with flat frequency response across a wide range, so that I don't mess up my mixes. (Unfortunately I have high frequency hearing loss above 12K and will be relying on others to occasionally listen to mixes and tell me if they're too bright or dark above 12K, or have some annoying whine or whatever, and looking at spectra to guess at what I'm missing.)
My question is mostly about subs. I've been looking the usual $400/pr or less suspects like the JBL 305P and the Kali LP6, plus random others I find in pawn shops (like the KRC Classic 5s I found today for $140 for the pair...)
And I don't know what to do about the low bass. Most of these small inexpensive powered monitors don't have a subwoofer out. I have inexpensive large consumer subs (with RCA connectors, not balanced inputs or crossover outputs) lying around that I think would be good enough for my purposes, but I don't know how to connect them with these monitors. It seems really weird that these small monitors have their own amps and nice balanced inputs, but no sub out, given that they do not generally have great bass extension.
I expect that I will mainly be using stereo XLR or TRS or TS outs from inexpensive USB audio interfaces, which don't have a separate sub out.
I may go with passive speakers and my old receiver, just because I know how to plug in a sub.
Am I missing something? What is the normal way to use a sub with these inexpensive, small powered monitors? (I'm not going to pay $400 for a matching compact sub that has XLR inputs and outputs to the speakers, that doesn't even have the bass response my big cheap consumer subs do... I'm not lacking for space under my mixing desk for a sizable sub.)
Is the normal thing to buy a "monitor" sub with an XLR crossover, or to buy a separate crossover, or what?
On a related note, I'm unclear on how to software EQ my speakers when I'm using a DAW like Reaper. Is there a standard way to interpose an EQ that works with various other audio software, on the particular audio interface outputs I'm using for my stereo mains? Or should I try to keep it simple, and get speakers that are flat enough (or can be using the switches on the back) without relying on software EQ? (EDIT: clarification: I will be using ASIO drivers for minimizing latency, e.g. lag when playing a software synthesizer. I am not familiar with the ins and outs of all the low-level software and don't know if the EQs that audiophiles use work with the software that performers use. I'm fairly new to all of this.)
