Looks pretty cool! Not sure what the fancy swirls infront of the woofer are though.I have been using JBL C222HP speakers on my HT for LRC. I am very happy.
To stop you punching the driver I guess. I have all speakers behind a grill anyway.Not sure what the fancy swirls infront of the woofer are though.
I will soon replace the centre with an upside down C221 though. The height of the C222 is pushing the TV too high.
No. I can’t localise the speakers. It feels like as if all sound comes from the large TV. I guess brain is fooled. When I listen to music, I only use the LR and it sounds like a normal stereo.I should say so! And I thought I had a problem! Do you lower the LR to match??
Yes, I use two JBL SSW-3. They are only fed with the LFE channel.Do you use them with subs?
SCL-4 is an in wall speaker. Mine are normal speakers with relatively shallow enclosures.I had looked into the SCL-4s but those C222HPs look very interesting.
I have a custom made ceiling-to-floor furniture unit that is built into a wide wall recess. It holds the LCR, the subwoofers, and the TV. Speakers are all flush with the furniture front, like in a sofit.Are they on-wall or free-standing?
It looks like I have completely missed the JBL Synthesis in-wall series. Stupid company splits their cinema range as Pro and Synthesis. Why? God knows! I will have some stern words with my dealer when he arrives tomorrow. Why hasn't he suggested these before?I had looked into the SCL-4s but those C222HPs look very interesting.
But with the usual M-T-M horizontal compromisesThanks to you I looked into the specs and found out that the model SCL-2 has a symmetrical horn. They even suggest the speakers to be mounted on their sides as well as upside down. This will allow me not only to be able to lower my TV but also align the speakers.
I thought of that and asked JBL to send me the spinorama chart and the polar diagram. I will not spend almost £20K without having seen proof.But with the usual M-T-M horizontal compromises
I ordered 3x KEF Ci5160REF. They are the in-wall version of the Reference 4C measured by @amirmWhat in walls did you end up going with?
