Hausmeister
- Joined
- Jan 8, 2024
- Messages
- 14
- Likes
- 4
Hi all,
I am thinking about an upgrade for my current system (Kef Q1 speakers on a NAD352). Ideally it should serve for Hifi listening and Music production and the budget should not exceed 2000€.
I have these speakers in a L shaped room (37m^2) with no treatment (and no treatment possible for the time being) and I have found quite some important dips for low frequencies. As a first step I tried to optimize the listening position using REW at many positions. I could get rid of an important dip at 80Hz but now I am left with a serious dip at 50Hz which I can't seem to eliminate.
Now here comes my first question:
1) If I can't do room treatment (this is our living room), does it even make sense to get better speakers?
The Q1 are not super speakers, but they have a nice sound to me, lacking bass however. But I'll probably find exactly the same dips for more expensive speakers below 100Hz. I understand that a subwoofer with EQ (such as the SWS SB1000 Pro) in principle could help below 100Hz, but as I can't highpass the Kef Q1 I would be limited to the range up to 50 Hz approx (which is where the Kefs "enter") in order to avoid a too large overlap.
Currently the older Neumann KH120A are available at good prices, so my idea would be to combine these with a SWS SB1000 Pro for the bass management. These speakers don't have room correction, but the SWS does (3 PEQ). They have a -7.5dB bass reduction option, which should make it possible to use the subwoofer up to higher frequencies, reducing peaks below 80Hz or so with the PEQ of the sub.
2) Could this be a good combination?
Of course the new Neumann KH120 II with DSP and Neumann Subwoofer would be better, but this would go well over 3000€.
Thanx for any info you can share!
