iLoud Micro Monitors measurements and quasi-anechoic spinorama
I went with JBL Studio 530 since I already had a pair and they're on sale again for $240. JBL doesn't even charge tax in my neck of the woods.
For an amp I also went cheap with the Aiyama A07. Noise is acceptable - I can hear it right in front of the tweeter but not a meter away. I was going to get a Topping PA5 if this didn't work.
For DACs I tried my Topping D30 and my Apple USB-C dongle and there's no real difference. Therefore, I will put the Topping back downstairs and just use the dongle most likely. I think with a better amp the dongle would be the limiting factor though.
If you don't want to hear the port noise from these toys - plug the port with something like foam.
I recently bought an MM, and am a little discouraged that almost everyone admires them.
Compared the sound with other speakers and studio monitors that I have.
The bass and lower mids lack transients, the upper mids and highs are somehow muddy.
The only thing MM is good at is blowing at 50Hz.
But, if it is used on a desk in super-near field, then sound becomes tolerable.
What's the effect on frequency response?
I know I can measure and I would do so in case I decided to go this way, just curious in case you measured already.
That's more or less their intended use, after all.
Keep in mind they are designed to be used at 0.5m, and that is the distance iLoud specifies in its specs. It's only really fair to compare them with speakers meant for similar applications.
The port noise seems to be an issue that varies by user so it could point to a QC problem.
In my case t recently upgraded to the MTM and realized that for super near field the bigger speakers barely made a difference using at 2 feet asay, especially when I'd hooked up my sub. The MTM are nicer but not by much. Similar with the Neumann KH80.
I've also mentioned before that's possible there are different versions of these as, for example, the measurements at No Audiophile are very different and describe a substantially different speaker(the switches on the back are different too).
But ultimately it's still a small speaker. Would be nice to know what speakers you compared to.
I know this, and I can't say that even so I like them. Just tolerable.
Compared to: kef Q350 (6.5'), Fluid FX8 (8'), and little cheap 1-way multimedia speaker F&D v520, which i made flat with EQ (maybe 2 inches).
When I first turned MM on, i was not impressed. And when I compared MM with others, the difference became unbearably obvious.
I didn't expect the highs and upper mids to be the worst on a 3" speaker. Its muddy. Not completely terrible, but I expected more.
Yes, and creating a port as thick as a finger, this is still a "brilliant" idea. Had to plug it. A passive radiator would be much better. The small F&D v520 has it,.. and there is no port noise!
Maybe I would like them if I didn't know what a normal hi-fi sound is. But I know! I also owned ATC, Eve Audio, Wharfedale, PSB speakers :)
_______
But I found a use - it is a great bluetooth speakers for my TV set. No subwoofer needed. xD
Met a strange problem during REW measurements of iLoud Micro. Right speaker did a click on high frequencies and shows the graph like this. Left channel is OK as you may see in previous measurement. Hardware problem?
Got the Micros today at the office. Everything needed to hook up to the computer including an audio cable was right in the box. Too about one minute. $250 (sale price) might sound like a lot for "computer speakers", which is how I am using them, and it is. But they're not "computer speakers", despite looking like something out of a 2005 "multimedia computer" PC setup. For size reference, they are over a full inch narrower than a Genelec 8010a (and way cheaper), and still manage to sound like real speakers. With bass. They take up virtually no useful desk space, which was my goal.
There is nothing muddy about the sound. The bass is great, which I EQed up quite a bit with a crappy parametric EQ built into the soundcard software to approximate a loudness curve for now. I need to work on getting a proper loudness control on these yet, since the volume will almost always be quite low. No port noise at any sane volume level for computer speakers. But, if you insist on cranking it, they are front ported, so if you do something stupid like play a 50Hz bass track, they act like fans to keep you cool! Dual purpose... And it is completely bizarre and requires some head/brain adjustment to hear as much bass is there coming from these tiny things. Best speakers in the world? Not by a long shot. Best speakers this size that can do what they do anywhere close to this price? Perhaps.
That is exactly how I use them, desktop speakers for my laptop that don't take up much space. They are WAY better than most crappy PC speakers like your Logitech and the like, at least the ones I've heard. Would I use them for critical monitoring? Hell nah. For YouTube, Spotify etc. on the laptop, hell yeah brother.
It's been over a month with these things now. Easily the best $250 I have spent on an audio component. They take up as much useful space as a coffee cup. Once you get the loudness contour figured out, it's almost spooky. It really does confuse your brain. It's the whole "you are there" thing at fairly low volume. 15 feet away with the door half shut, you can't hear anything. With the 50Hz bass, I am going to go out on a limb here and say I would rather have these than the similarly sized Genelec 8010As--by a mile. The F3 is lower than most good bookshelf speakers. It's weird. IK Multimedia made the right call, and it's a call almost no other speaker manufacturer has ever made.
What EQ/vst/tool did you use for that? Fairly low volume is recommended 60db?
Just grabbed a pair of these used locally since I found a good deal. Am a bit confused about input selection. It has Bluetooth input, and the slave speaker has 4 pin input, which suggests biamp and internal dac. So am assuming these have DSP filters. But only physical inputs are analog? What gives? I need to use a separate DAC just for it to be converted back to digital and then analog again?
One argument is that digital input is still cost and you can't do without analog inputs and analog inputs can do what digital inputs do anyway.
At least you can save money by using the cheapest DAC. Considering the use case for these speakers the typical DAC costs $0 (free built-in) anyway.
Just seems weird to me. Whether or not it's audible, it seems weird that my chain must consist of digital to analog to digital to analog. They even include 2 analog inputs. Why not one analog and one digital? How much would an optical/coaxial input really cost?
I have their much larger and louder cousins (Precision 6) and I still slightly prefer the Micros for 60-70dB @ 0.5m listening.
Impressive considering how comparatively crappy their amps probably are.
What did you do to get the loudness contour? Curious about what you are referring to. I guess it's something along the lines of "lower volume needs extra emphasis on bass and highs" to follow human hearing profile at lower volumes.
Following up on this old post and some requests for settings, the trick is to do something that at first sounds ridiculous: Apply about 18 total dB of EQ. Ideally it would be a little more, but this is about what the speakers can manage. All I did was use a very basic parametric EQ roughly following the Fletcher/Munson curve. Played on a frequency sweep, it sounds as if everything is close to the same perceived loudness with not that many bands of EQ, starting at 50Hz or so. 31Hz cannot be boosted to where it should be, so +6dB there or as high as you dare under about 60dB. Then, +7dB at 62Hz, +3dB at 125Hz, then dropping down to -4 at 250, -8/500, -10/1k, -10/2k, -11/4k, -5/8k, +5/16k. Adjust to suit. That's not a lot of bands, but it is enough to work. At the levels I typically use at my desk, which needs to be inaudible with the door shut, "flat" sounds like a clock radio. This sounds like full range speakers, and you will get "flat" bass down to just below 50Hz. It will take a few minutes for your brain/ears to adjust, and then tweak with a frequency sweep as needed. Note that you can't turn it up much if at all like this. I think the iLoud is the smallest, but similar tricks are probably possible with ADAM D3V (or Kanto Ora), but these are still easiest due to 3.5mm TRS or RCA input.
