I disassembled my Event Opal
MarsianC#
Austria
Already posted in other forums, but after the post on the 8351B I thought you might enjoy my pics too.
The Opals a quite similar, aluminum housing, heavy and good sounding. Measurments by S&R are very good too.
I really like them ;)
Absorbend material is usually around the tweeter, a big sack with glasswhool in it.
img-20200408-184633889-li_1006964.jpgimg-20200408-183152071-li_1006963.jpgIMG_20200408_183417207.jpgimg-20191202-143336222_977485.jpgimg-20191202-143354855_977487.jpg
Tweeter is not the beryllium one used before 2011. They use one made by Seas, at least in my model, built in 12/2012.
pozz
Слава Україні
Editor
Benjdare
View attachment 78596View attachment 78597View attachment 78599View attachment 78601View attachment 78600
I also own a part of opals with the Seas tweeter.
mine seen to have a problem of one tweeter cutting in and out. I have to turn the volume up quite loud to reactivate the tweeter and it giving me the shits . I paid $4000.00 for the new but have only used them less than a dozen times, do you have any idea what I could do to fix the problem. I have changed the leads and I run a Motu 828x from a Mac for dedicated sound rack?.. any ideas
AnalogSteph
.de
Contact issues of some kind. Since I do not see relays anywhere but do see plugged connections for the drivers, I can only suggest unplugging and replugging those (a tiny bit of contact cleaner may not go amiss), as welll as inspecting the connectors' solder joints and reflowing any dry ones.
