Dear all.
I have recently installed a phono amplifier (Pro-Ject Tube Box S2) using my new MC cartridge (Denon 103R). I use a Garrard 401 turntable with a SME 3012. It is amplified by a Sansui AU9500 integrated amplifier. Using the Pro-Ject manual and searching on the internet, I have installed the phono amplifier with 60 gain and 470 ohms.
The sound is great, but I think there are a few problems that needs to be raised.
First of all it seems after playing a record, a humming sound begins to appear. I tried to find the problem, but I am no technical expert. Therefore I would be delighted if you could please comment on the situation.
- There are no humming sounds when I play digitally, that is without the turntable.
- There are no humming sounds when I play the records without the phono amplifier, however I need to turn the volume up dramatically.
- If I turn off my turntable and my phono amplifier is connected, the humming is present but more discreet.
- If I turn off my turntable and my phono amplifier, the humming sound is not present at all.
Additonal actions/thoughts:
- I have installed the phono amplifier at 100 ohms, but after a while the humming reappear.
- I have tried to reconnect the ground wire. It is an old ground wire and the copper seems teared and fragile. Perhaps that is the problem?
- I have a simple power rail. Not sure if that has anything to do with this specific situation. Would it be better to invest in a good power rail?
- If I turn on "LOUDNESS" on my Sansui and turn up the volume I will immediately get feedback so I have to turn the volume down. Speakers are approximately 1-3 meter from the turntable. The turntable is approximately 1 meter from the amplifier.
Thank you very much in advance for your time and considerations.
Best regards.
Best regards.
