How true? Class D amps can't sustain their maximum spec'd power
JohnYang1997
China
OK I think that is a great way to look at it both practically and for the consumer.... now we just need everyone to agree that this is the new standard :).
This is the existing standard CEA/CTA2006. And it's the most acceptable one and it's virtually used by most reputable manufacturers. And it's exactly what Amir uses for "peak" power. You can read on the top of the graphs.
Doodski
I still remember the SoundDesign all-in-one el-cheapo system I had to repair way back when that was rated something like "1000 W instantaneous dynamic music power". That from a 2N3904/2N3906 output stage. Yes, "output", not "driver" stage...
LMAO../ I rebuilt PWM power supply after another that had that 2N39xx whatever designation. It was a major mess @the time. A bunch of small transistors in a switching power supply in the middle of stuFF..
Head_Unit
without much "peak headroom" I wonder if it is a disadvantage.
I *suspect* that a really hard regulated amp with no headroom would perform more ideally up to clipping. More like the voltage amplifier it should be. Of course this could depend on all kinds of factors! Nevertheless I feel this might be why some high powered built-like-a-tank amps are felt to have "more control" even when not played up near clipping. Needs more research...which will never happen...
restorer-john
Amplifiers can behave perfectly well up to, and into clipping and others can momentarily latch up, oscillate, or otherwise lose control. The modern Class Ds are excellent at the onset of clipping in the limited tests I have done. I have plenty of older amplifiers that can do some crazy stuff as the NFB loop loses control.
The thing is, as the current being delivered by the amplifier increases as you push more power, the devices in a typical Class AB drop more and more voltage across their junctions, emitter resistors and, at the same time, the main rails sag as well. So you have these dynamic modulations of the supply rails resulting in non-linearities that the amplifier vainly tries to correct via feedback. Most high performance designs will run the front end (differential stage, current mirror/s, VAS etc) from a separate and regulated higher voltage supply, so the actions of the output stage (the current amplification part) do not affect it so much.
But a huge number of typical class ABs, just attempt to decouple the front end supply rails, via a resistor or two and some caps, which can also mean the front end voltage is incapable of driving the output stage to its full potential.
The FETs used in Class Ds already have a phenomenally low Rds(on) (resistance source-drain) which means the losses due to drops over the device are much lower. Combine that with super fast switching with little time between off and saturation and you have fantastically low losses.
Taking amplifiers right up to the edge of clipping under load and watching their behaviour live on a 'scope is most illuminating. All amplifiers are not created equal and they certainly don't perform the same or sound the same in that situation.
