Neutronman
- Joined
- Jan 13, 2021
- Messages
- 52
- Likes
- 5
Hey Guys,
I tried searching on the forum for specific articles, but I was not able to find anything. My current set up is music played through PC using Soundblaster ZX and listening through Sennheiser Momentums and Meze Neo 99's. I finally took the plunge and bought Topping DX3 Pro to play my music. Sources are Spotify, Tidal, MP3 and Flac audio files.
I use Music Bee to play local files with ASIO enabled in the music player. I have no other tweaks, everything is set by default.
My plan is to uninstall the Soundblaster, disable onboard motherboard sound, install the Topping USB driver and connect the DX3.
Are there any setup tweaks I should know about to get the best out of my headphones and the DAC/AMP? Is Asio the best setting on Music Bee? Are there better Windows players out there I should be using? If so what and recommended settings?
I appreciate your help and advice.
Thanks.
Greg
Thanks.
Greg
