Here are the LCR measurements with my UMIK-2 in the main listening position. My Macbook connected to the Denon 6700 via HDMI 2. The midi was set to 8-channel, 16-bit, 48 kHz (this was a mistake, I meant to use 24-bit, but it was left this way when I was troubleshooting the connection). The UMIK also uses 48 kHz sample rate. REW was setup to use the Denon-AVR sound device and I verified the 8-channel mappings for LCR, LFE, SL, SR were correct.
The spectrograms seem to have decent control under 200 msec, except maybe in the 100-300 Hz range. But there is not much of a red band -- i don't know if that's good or bad (I suspect bad).
The RT60s show a couple spikes in the 100 - 300 hz range for the LR, and a big dip for the center around 180 Hz.
The SPL shows a pretty big drop for the center around 180 Hz, which seems to correspond to a "peak energy time" spike in the spectrogram and a big dip the in th RT60. The left has a big dip around 360 Hz.
I'm not sure why the LFE shows about +6 dB over what I would think of as "smooth" -- I'll need to review the Audyssey app PEQ settings.
I could not figure out how to get the RT60 chart to display the time to distance conversion on my mac.
These are the corresponding RT60 plots
And this is the combined (1/12 smoothed) SPL. The LFE is a Sigberg Inkognito 10 on Preset #1. It is against the front wall on floor stands. There is a second sub (an older klipsch) on the side wall, on the Denon sub 2 output, but it did not seem to be used in the LFE test.
