How import from Qobuz to iPhone
Fahzz
Outside Providence
I can't figure out how to import albums from Qobuz to my iPhone. I don't have unlimited data, so I need the albums stored on my phone and I was able to do this a couple of years ago. But now I can't get them from my PC to the phone. I went through the procedure to download them to ''offline" but nothing shows up in the phone offline library, and pushing the "imports" has no effect. Qobuz instruction on this are limited. Help is appreciated.
Jimbob54
You mean something you favourite in qobuz streaming (and select to take offline) rather than actual purchases of files from the Qobuz download store?
If so, you can't. They are locked to the device you select them to be "offline" on.
Fahzz
Fahzz
Outside Providence
Thanks. They must have changed something, because I've used it with CarPlay previously.
JCM800
If you’re just downloading offline copies of your Favorited, you just download from the phone app. Little down arrow next to the play button when viewing an album. No pushing files from PC to phone or vice versa. Am I missing something?
Fahzz
Fahzz
Outside Providence
No, you're not missing something, I am. The app wasn't showing favorites at all. I deleted the app and signed in again, and it appears to be working. Thanks.
Jimbob54
My apologies- I thought you meant transferring files you had downloaded from your PC to your phone- not just re-downloading some favourites direct to your phone on the Qobuz phone app.
Fahzz
Fahzz
Outside Providence
That’s weird. Glad you got it sorted out!
I had signed in originally with my Apple ID. When I tried again using my Qobuz user name and password the problem was solved. It's still a time consuming process. I had hoped that there had been some improvement since I last did this, but nope. Thanks.
