So currently I have an AVR with Airplay built in. In this setup I can simply airplay to the AVR and then control the volume using my phone directly. My phones volume will be the same as the AVR’s volume and vice versa. So one volume control.
Now for another setup I’m looking at a separate stereo integrated amp and a streamer combo. However I don’t quite understand how volume control works. It’s going to have double volume control; on the streamer and on the stereo?
It would be connected like: streamer > optical > stereo.
I figured maybe if the streamer has a fixed volume level you could control it on the stereo, but then, since it’s fixed, volume control on the phone for for instance AirPlay won’t work?
Vice versa if you set the stereo amp to fixed you could and leave the streamer variable, you could only control it through your phone (the streamer has no volume knob), but then you couldn’t control the volume using the amp.
Is that normally how this sort of setup works? It feels very clunky compared to a solution where it’s all built in? Or is there a workaround for this?
I do like being able to use both my phones volume AND the volume knob on the stereo itself.
