What would you choose for mastering?This is the only Amphion spinorama we have:
Ouch. Major issues present.Amphion Argon1 Quasi-Anechoic Spinorama and Measurements (Updated)
I recently got the Ampion Argon1s in for review. Though I haven't had time to run the full suite of measurements (hard to find the time to run 70 sweeps without annoying my SO) I did run some horizontal measurements today. I'll probably redo them as they were a little more rushed than I'd...www.audiosciencereview.com
I would choose Genelec any day over these, especially for mixing, where neutrality and low distortion are important. In other words, Genelec and Neumann are kings of mixing monitors, for a good reason.
KH420s, 1237s, ATC 110s, something that can be flush mounted in a dedicated room.What would you choose for mastering?
Argon 1s are from the hifi range and are ported, so probably irrelevant to this thread.This is the only Amphion spinorama we have:
2-way vs good 3-way.That’s a whole lotta IMD in that One18…
It has to be noted that the scale on the IMD graphs is not the same for the three speakers.That’s a whole lotta IMD in that One18…
Good points…Jeesh, complex passages must sound like a cacaphony.It has to be noted that the scale on the IMD graphs is not the same for the three speakers.
- Amphion One 18 : 0dB to 100dB, volume at 90dB
- Genelec 8331A : 20dB to 100dB, volume at 90dB
- Genelec 8361A : 30dB to 110dB, volume at 100dB
Therefore, the IMD looks much worse on the One18 compared to the Genelecs. And even the 8331A and 8361A are not comparable since the volume at which they have been measured is not the same.
That being said, and all other things being equal, a good three-way is indeed going to be better than a two-way speaker as far as IMD in concerned, as thewas pointed it out.
