Hello, all.
I finally have a preamp with tape loops (yay!). I have put an equalizer in the tape loop…but I am having problems.
I believe I have it set up correctly. The tape out from the preamp goes to the input on the equalizer…and the output on the equalizer goes to the tape in on the preamp. There is also a tape monitor button, and when I press this button, the equalizer is applied. Perfect.
The problem is when I select Tape as the SOURCE on the preamp. (I understand that selecting Tape as a source makes no sense with this setup, but this is unavoidable for at least a second due to the preamp’s design when changing sources).
When I select tape as a SOURCE on the preamp, and the equalizer isn’t flat (in this case, the low bass was boosted), I get a HORRIBLE, LOUD, speaker destroying sort of low pulsing sound. I tried two different equalizers and had the same result. This is both with and without the preamp’s tape monitor button engaged.
I theorize that it is feedback…the sound of the EQ circuit is going into the preamp, out to the EQ, into the preamp, out to the EQ, etc - and creating a horrible feedback loop. Am I right? What can I do? Does the presence of tape as a source (not just the monitor loop) mean I can’t use an EQ in the tape loop?
Preamp is an Akitika PR-102.
Thank you!
Thank you!
