It will not matter what you tell him, he doesn’t listen or understand the basics .
Show us what you can get.
Music Systems
Rotel music systems feature stereo components including integrated amplifiers, stereo amplifiers, stereo preamplifiers, DACs, and CD Players.www.rotel.com
We are discussing what is available in your country. You show us what is available in your country.https://docs.google.com/spreadsheets/d/1ZlTOYxmPs938gqHjtDABkWS-MApu7uJjzIGnJ2Elm6Y/edit#gid=0
based on the chart rotel is at 210th.. place
nad is at 62th place with c399...
based on the chard they are way behind...
i have no clue good auto solution is best for my case.@bladest you need to start with basics. What's a Fixed frequency EQ, what's PEQ and basic high/low pass/self filters and learn how to use them.
@bladest Creative fall and raised couple of times. Last time they went down Intel bought division that whose making it's property large area complex ADSP meshes. GPU's are more or less the same thing but with reduced functionality to what is relevant for graphics. Or at least it whose like that now you have separate GPU's with additional DSP processing blocks for data centres from leaders like Nv and of course duble precision FP operations (FP 64) are locked (by divider) on all consumer cards from beginning.
There are free and paid VST plugin's (of 1st, 2nd and 3rd generation), good and bad, simple and complex to the order of containing complete DAW in single plugin. Usually either players have embedded support (JRiver for example) or third party plugin that enable use of it (Winamp, Foobar2000) while most DAW have embedded support for such and traditionally on Windows all do Linux support is also maturing.
This is a DAC. It does not do any DSP.i want high end Dsp but for small amount of money i like dsp from benchmark
https://benchmarkmedia.com/collecti...rk-dac3-hgc-digital-to-analog-audio-converter here is example of dsp.
I need you to show me what is affordable and in your price range.i have all rotel current models + michi,.
i am not into thinkering with stuff,Start with something handy and cheap and learn. For beginning try with your smartphone and Neutron player (evolution free version is fully functional for 7 days after which it gets annoying and stops the playback after 15 min or so but EQ is fully functional). It has both simple EQ and full PEQ with all filters and in graphical representation along with 64 bit FP engine. Cheapest way to learn.
OK> I see the Rotel.ca webpages for the MKII models. What else is good in your country? Show me more.Rotel RA 1592MK II
Rotel RA 1592
Rotel RA 1572MK II
Then you absolutely do NOT want a DSP, at all.i am not into thinkering with stuff,
To be fair it does mention DSP as one of its selling points.This is a DAC. It does not do any DSP.
HelloWelcome @bladest ..
Could you tell us what you want to accomplish? From there we may able to guide you.
Just so that you know, you and most people on this planet named Earth, may not be able to distinguish between an amp with SINAD of 75 to another with a 120 SINAD ...
So.... Keep this in perspective and ...
Let's hope you are also seriously asking the questions... We've been trolled before. We (I?) have come to be a bit suspicious...
Peace
I suspect they meant high headroom to allow for DSP. Not massively clear though!
