Amateur2020
- Joined
- Jan 21, 2020
- Messages
- 56
- Likes
- 17
Hello,
I was searching for help and I founf this very interesting page. The ting is that I have a system based in an amplifier NAD C316BEE + CD reader NAD C516BEE with a DBX Driverack PA2 for room correction in a 16 m2 room and I am trying to decide between to pair of loudspeakers:
set 1: 2 x DALI Zensor 5 + 2 x MIVOC hype 10g2 subwoofwrs
set 2: Dynavoice DF-8
When I pass the autoEq get this graphics (which I think I do not interprete OK)
the green line is the result of the EQ
the grey line is the room effect
the white line is the parametric EQ
the orange flat line is the target
Set 1
Set 2
Well, in principle seem to be very similar but set 1 sounds much better and bass is more deep. According to specificatios DF-8 go to 23 Hz. and should be equals Maybe the room is too small.
The thing is that I am un a triangle of about 2 m, and usually I listen music at about 75 dB or so.
I prefer set 2 because is less space.
The question is if regarding those graphics, I do not trust my ears to do this, do you think there is something to change in order to improve the sound.
Thank you very much.
Best regards,
Set 1
Set 2
Best regards,
