By modifying the audio data?
Yes, it is filled with spikes of 90.3dB, they are actually very accurately exactly the same.
But that is noise on the digital connection, right? Not actual audio.
The noise is
always present, and it does screw up actual audio I captured.
My 1kHz sine wave was littered with this noise.
Some pictures, using 192kHz as input sampling rate (I tried 44.1, 28, 96 and 192 -> all the same)
Top is the left channel of the SPDIF input, bottom is the same with 90.3dB gain
Note that I captured this without an actual input source, but as said, it is exactly the same when inputting an SPDIF stream with null values. Zoomed in it looks like this:
No need to debug my system as I don't use it for audio, but I think it illustrates the level of noise that
may be present on the PC side on the direct digital interface - it almost seems deliberate.
