As long as you have battery power that is a great solution.I take a photo on my phone and zoom in. The phone has a light, too; the chances of me having a magnifying glass and a torch at the same time are minimal, and then I'm using both hands...
@MattHooper
The better option these days is a USB microscope with stand, which you can also use for setting alignment and VTA/SRA.
As well as azimuth, if one is using a visual, as opposed to electronic, method.
@MattHooper
Friction.Aggghh!
Took off my cartridge and gave it to my pal - who is pretty experienced with turntables. He put it on his turntable and has played a bunch of albums: no distortion he says and it sounds like a great cartridge!
He'll keep the cartridge for a while to ensure the distortion doesn't crop up, but on my system I would have heard distortion already.
So...if I replaced my phono stage, have even tried a different amp (Bryston my friend lent me), tested my pre-amp (digital signal has no distortion through my preamp, and distortion follows the phono signal if I put the cable to my usual digital aux input). I've wiggled wires going in and out of the phono stage. Now the cartridge seems ok.
WHAT'S LEFT?
The tonearm? Not sure how this shape shifting distortion could be due ot the tonearm, but what do I know?
Aggghh!
WHAT'S LEFT?
The tip could be fine but the suspension could be shot.Update:
My friend just phoned: "It's the cartridge" he said.
My friend had been listening to albums and getting great sound for quite a while. But then things started distorting on energetic transients and it got worse until the sound was just distorting.
So, I guess that's it.
Dang, that was a nice expensive cartridge thrown in to the deal when I bought my turntable second hand. Benz Micro Ebony L. Cartridge is a little over 3 years old, played probably 1 - 2 hours a day over that time.
Deciding what I'll do (e.g. get that cartridge re-tipped/replaced) I asked my friend for an evaluation of the cartridge while it was working well.
He has had, and still has, many different cartridges (he reviews vinyl equipment) and is actually a cheap-skate by nature, usually advising me to go the cheaper route normally because of diminishing returns/exaggerations about differences in performance. So normally he'd tell me "ah, just replace it with a $500 ortofon, everything else is diminishing returns at best. I was sort of fishing for that advice. But he said in this case he had to tell me, that thing is a really great sounding cartridge and, yes, to his mind worth the money to re-tip/replace if I'm looking to maintain the level of performance I'm used to.
So there it is.
Much thanks to all who helped me out in this thread. I asked many people their opinions and most were scratching their head over how it could be the cartrdige given the weird variation and transient nature of the distortion. I still don't get how it would play perfectly for many albums at my friend's place and THEN start distorting all over the place.
I've gone through so many cartridges, most gave up the ghost when the stylus shank bent or the tip wore out. I remember reading in a Hi-Fi magazine how the suspension's plastic could lose elasticity over time, making NOS cartridges a big gamble. Something about ozone eating the elastomer. Again, I've gone through so much of this over time, I'm relieved to not have to deal with it any more. Swapping out old for new sounds like a good idea. I know when things are going well for LP playback, it can be hypnotizing. However, I've taken the cure.I appreciate all your suggestions Robin. Thanks again!
Benz Micro has a trade in program, so instead of just re-tipping (apparently quite expensive) they'll give a new cartridge at a substantial discount.
I'll see how that goes probably first.
Man digital audio sure is nice.
Update:
Well as I age, I find being hair shirted isn't as appealing as it once was. Taking the EZ way out is okay believe it or not sometimes.EZ MODE
I'm just funning with MattHooper anyway.
I at one point decided the quality of digital was better than Lp and tired of keeping duplicate systems. I was working then. Were I retired I too might have never gotten rid of the old records. But now retired I'm not going back. I had several hundred LPs and selling it off was a chore, but okay once I had done it. I even had providential interference just as I made the decision. Someone out of the blue offered me a trade on a top of the line Sota Cosmo TT for an extra DAC I was selling. I had always wanted a SOTA but had never spent quite that much money. I ended up doing the trade as economically it was a sweet deal for me. A buddy also wanted a SOTA at the time. I called him up and said, "hey, if I could get you a Cosmo for this much money would you want it?" He said yes sort of not believing me. When I got the SOTA in, took it straight to my buddy's house and never opened it up. Too tempting. My buddy had like 8000 LPs so it went to a good home. I spent the proceeds on a Wadia DAC.
A Martin DRS2 is even better:Digital is great if all you want to do is listen to music.
Folks,
Recently I've had a problem with distortion creeping in to my LP playback system.
Initially when the system is turned on, playing a record (that is in good condition) will sound clean enough, but after a few minutes distortion will start to occur, at first just barely "is it there?" level of grittiness and then it gets worse until the sound is covered in a layer of haze/fuzz, with transients distorting very obviously, like an over-driven amp. Or the type of fuzzy playback you get when a big hunk of dust got hung up on your needle. (The needle is fine, I keep it very clean).
I turn the system off, and the same thing happens the next time I use it.
Any ideas for trouble-shooting this?
My turntable and Benz Micro Ebony L cartridge and phono stage are 3 years old. Well cared for.
I don't know how it could be the stylus, which as I say is kept very clean and not sure distortion would have this type of "starts clean, becomes really distorted" character ever time.
And my tube amp/tube pre-amp seem fine: my digital source displays no distortion.
Which makes my hunch go towards my phono stage. It's a JE Audio phono stage that uses 2 small 6H30 tubes as buffer stages. I'm wondering if this might be a sign of a tube or both going south? Any other ideas?
Thanks for any input!
