ChurchSoundGuy
- Joined
- Dec 20, 2023
- Messages
- 14
- Likes
- 6
Hello,
Recently purchased a new pair of Senn HD600, unfortunately I found them excessively bright and attacky, especially around the snare drums and hi-hats. Having spent ages going through numerous suggestions on EQ etc, i found an EQ that worked very well for the pair I had and wanted to save anyone else that may be having the same issue with them (assuming your set are anything like mine).
Oratory1990's new HD600 EQ works really well in Equalizer APO as a baseline, and tested a few other settings that i found elsewhere and collated them here with a HS that works for me, but there was still the snare and hi hat attack issue, which i added a few bits to for the 'treble fix':
Hope this helps somebody else too!
Code:
Preamp: -9.3 dB
Filter: ON PK Fc 20 Hz Gain 4 dB Q 1.1
Filter: ON PK Fc 97 Hz Gain -2.5 dB Q 0.7
# Bass preference - default 5.5db
Filter: ON LSC Fc 105 Hz Gain 5.5 dB Q 0.71
# Warm preference - default -1.7db
Filter: ON PK Fc 215 Hz Gain -1.7 dB Q 1.1
# Midrange perference - default -2.1db
Filter: ON PK Fc 1400 Hz Gain -2.1 dB Q 1.5
# Treble preference - default 3.0db
Filter: ON HSC Fc 2000 Hz Gain 2 dB Q 0.71
Filter: ON PK Fc 2700 Hz Gain -1.3 dB Q 3
Filter: ON PK Fc 3370 Hz Gain -3.9 dB Q 2.5
Filter: ON PK Fc 5350 Hz Gain -3.5 dB Q 3
# Air preference - default -4.0db
Filter: ON PK Fc 38.02 Hz Gain -4 dB Q 0.71
# My treble fix
Filter: ON PK Fc 12400 Hz Gain 1 dB Q 3.9
Filter: ON PK Fc 8000 Hz Gain -3.9 dB Q 3
Filter: ON HS 12 dB Fc 13765.1 Hz Gain -3.9 dB
