Is there any way I can fine tune the bass and high mids of this speaker.
I plan to look for a preamplifier for this speaker. Does that help balance the sound of this speaker?
Which preamplifier should I use? Thanks for helping !
Thanks StaticV3. Thanks for your advice. I always use the SoundStick 4 speaker fully connected using the 3.5mm port, and I've always been clear that the wireless connection doesn't sound really good. So what preamplifier can I use to be able to tune the bass and treble range?Hi @nhamcho93! Welcome to ASR.
You can use Equalizer APO to fine tune the bass and high mids of your SoundStick 4. The software is extremely powerful.
A preamplifier will not help balance the sound of the speaker, unless the preamp has built-in EQ or room correction (expensive).
You can use the Alternative A2DP Driver to unlock higher quality Bluetooth output on your PC.
Lastly, a measurement microphone (UMIK-1, Micbooster EM258) is extremely effective for quickly correcting your speakers. Highly recommended.
I would buy an Apple headphone adapter, do PC->Apple adapter->SoundStick, then install Equalizer APO and use it to tune the sound.Thanks StaticV3. Thanks for your advice. I always use the SoundStick 4 speaker fully connected using the 3.5mm port, and I've always been clear that the wireless connection doesn't sound really good. So what preamplifier can I use to be able to tune the bass and treble range?
Can you guide me to install Equalizer APO. Thank you very muchI would buy an Apple headphone adapter, do PC->Apple adapter->SoundStick, then install Equalizer APO and use it to tune the sound.
A preamp with EQ costs upwards of $500, which is absolutely not worth it when EQApo achieves the same for free.
Here's the download link: https://sourceforge.net/projects/equalizerapo/Can you guide me to install Equalizer APO. Thank you very muchView attachment 365222
I downloaded and installed but nothing happened after that?Here's the download link: https://sourceforge.net/projects/equalizerapo/
Here's the installation and configuration guide: https://sourceforge.net/p/equalizerapo/wiki/Documentation/
One thing that the guide doesn't mention is that you can configure EQApo with a simple Editor GUI (It's called Configuration Editor). There's no need to mess around with .txt files.
Wdym by nothing happened?I downloaded and installed but nothing happened after that?
Can you suggest some customizations of the Sound Stick 4 speaker for me?. I find the Peace software quite difficult to control!Wdym by nothing happened?
EQApo doesn't change the sound just by installing it.
You have to open the Editor and make changes yourself.
I don't use Peace and don't generally recommend it.Can you suggest some customizations of the Sound Stick 4 speaker for me?. I find the Peace software quite difficult to control!
Actually I can't figure out how to open equalizer apo without opening Peace.I don't use Peace and don't generally recommend it.
I use the default Equalizer APO Editor, where for the most basic sound adjustment, you can simply add a -10dB preamp (to avoid clipping), then a 10-band graphic EQ.
If there's too much bass, simply reduce the sliders on the left.
i got it. Thank you so much !You just double-click the Editor:
Btw, if you have an iPhone or can borrow one, then you can measure your SoundStick's response with the HouseCurve App and use that to make corrections.i got it. Thank you so much !
Yes. I have iphone 13proBtw, if you have an iPhone or can borrow one, then you can measure your SoundStick's response with the HouseCurve App and use that to make corrections.
No measurement mic required.
