After spending a good month selecting in vain for appropriate passive speakers, I think that I need outside advice to continue even before scheduling auditions.
The intended application:
Not entertainment but rather precise and professional listening to classical music in a 18 sq. meters bedroom.
Here are the entry requirements with decreasing preference:
(1) The speakers should be good for high quality FLAC recordings of classical music of all genres, including solo piano, solo violin, solo flute, concerts, symphonies and organ.
(2) The speakers should reproduce the recording precisely without "improving" it.
(3) The speakers should be made from non-toxic materials for as long as this does not compromise the sound quality in the sense of (1) and (2). I consider toxic any plastic (PP being the least evil), plywood-type materials (MDF being the least evil) and any glue.
(4) The speakers should be the cheapest among those which solve the problem.
(5) The speakers and all their parts should be made fully outside of the PRC.
It seems that I am looking for something one would call "monitors" with closed cabinets which confidently reproduce frequences up until 26kHz at least. I also hope that I can focus on bookshelves and that the entire system, including the amplifier will cost me not much more than 2000USD. Given the market reality, I do not believe that the requirement (5) has any hope to be satisfied so I mention it as a wish at the end. The same holds of course for glue and MDF in the construction of the cabinets. I have not decided on the material of the tweeters as there are so many conflicting views on this. I am not 100% sure that I need passive speakers.
For now I shortlisted the following models:
KEF Q150
DALI Oberon 1
DALI Zensor 3
DALI Spector 2
CYRUS OneLinear
FOCAL Chora 806
ELAC Debut 2.0 B5.2
ELAC Debut 2.0 B6.2
OPERA Mezza
AQ Wega 52
WRS MM6
PHONAR Veritas m4.2 NEXT
There are definitely many more options to consider. Could someone kindly help me to make a choice by sharing his or her thoughts about the models listed above or pointing out other options? How do they compare with each other from the point of view of my entry parameters?
KEF Q150
DALI Oberon 1
DALI Zensor 3
DALI Spector 2
CYRUS OneLinear
FOCAL Chora 806
ELAC Debut 2.0 B5.2
ELAC Debut 2.0 B6.2
OPERA Mezza
AQ Wega 52
WRS MM6
