I know, it is nuts that one has to spend 3 times the cost of a PS4 Pro or XBox One X for a graphics card that runs things acceptably at 4K.
But what really annoys me is that the video card manufacturers just do not seem to give a crap about coil whine that their cards produce or the interference that they dump down the common ground. At least PS4 Pro uses a 2-prong cord which eliminates the latter problem. However, most PS4 Pro consoles, including my own, have a very pronounced coil whine emanating from the unit itself that is easily audible in menus where the frame rate is uncapped (for some reason). I had to put mine into a ventilated closet just so that the coil whine and fan noise would not bother me. With PCs, you can control the fan noise easily, you can cap that frame rates which helps the coil whine, but electric interference via common ground is still an issue.
