www.audiosciencereview.com
Incorrect fact claims are not opinions. My statement was intended more for someone looking in so that they understand that this is make-believe, not actual electronics or sonics.Luckily, those points of view are subjectivly based on "opinions" of either side
As long as everone is satisfied by his personal choice I really don't care...
You do not seem to know the difference between indisputable fact and opinion. If someone is curious and stumbles on this thread, here is the difference:Luckily, those points of view are subjectivly based on "opinions" of either side
You've never had any tube gear before and while the JAN5725 pre amp tubes are fine you are listening via an s/s output that maybe not be anything like the optimum. Indeed the Philips amp also might not be operating at anything like optimum as it is an 'old' amp, any electrolytic caps might well need replacing. What model is the Philips, how old? If you are going to A/B then it's only really a valid test if it's an all valve amp of the same age and better yet of the same kind of initial value.They're companies trying to make money, so I guess a wider variety of offers will attract a bigger audience...
"Audiophiles" have all sort of "audio fetiches". Some have the tube fetiche (here's a tube amp for you), some have the modding fetiche (here's an amp where you can swap some parts...) and so one...
I think the T9 is there just for those tube freaks... I never had anything with tubes so I thought I'd give it a try. It looked neat too. Got me sold initially... Sound wise? meh... So it went back (thank you Amazon for the great 30-day no-questions-asked return policy).
I'd like to try some "good" tube amp some day, but T9/T9 Pro definitely doesn't make the cut...
I also agree that tone control would be nice... But on the other hand I like the minimalism of it... hopefully means they had more time to focus on fewer design decisions and had more money to spend on fewer, but better components...
The T9 Pro was a hell lot of things in just one package... not surprising that it's not good at any of them...
I'll post back my thoughts on the Fosi V3 when I get it...
That probably is the reason, why each has his own impression and personal preferences considering this. All OP amps seem to have at least some sort of "audio" character of their own, allthough measurements don't seem to show this
I don't know, if everything of those stated "sonic" characteristics of the chosen OP amp are really exist, but many seem to believe in it, imagined or not.
Neither "school" can prove their points ultimately, so you have to setup your mind yourself,
Wait...are we arguing you should just pile on more distortion on playback, because (for example) Hendrix' guitar amp makes 30% THD?Never forget that violins, acoustic guitars, cellos - hell all acoustic instruments and yes electric guitars are examples of listening to distortion. If your amplification doesn't mirror via speakers/headphones the distortion of live music - what exactly are you listening to?
No. Harmonics are NOT distortion, they are a component of the original signal. And if electronics have low distortion, those harmonics will be reproduced faithfully.Never forget that violins, acoustic guitars, cellos - hell all acoustic instruments and yes electric guitars are examples of listening to distortion. If your amplification doesn't mirror via speakers/headphones the distortion of live music - what exactly are you listening to?
Personally, I prefer listening to music, not to preamps.I ended up using preamp tubes that were an end game and if I can find a really well designed preamp where I can use the transparent Russian K73-16 caps and Z foil resistors using a Tung Sol 6F8G x 2 output Russian 1578 tubes into my Hypex power amp would be something to listen to.
Exactly. Even if they were purposely generated during the performance.Harmonics are NOT distortion, they are a component of the original signal.
Siy the Russian Caps were as as cheap as chips. There was an excellent thread on diyaudio all about these Russian mil/spec caps. Like a lot of others I was skeptical about this thread started by a London based medic who had shelled out plenty for exotic expensive western made caps and then found these.No. Harmonics are NOT distortion, they are a component of the original signal. And if electronics have low distortion, those harmonics will be reproduced faithfully.
If exotic caps and resistors are your fetish, great, but fashion stuff won't work in audio circuits any better than appropriately chosen (and vastly more inexpensive) mass-produced parts. And very often, not as well.
Those silver foil caps were good but the Russian caps were like the Vishay Z foils - transparent.
I never comment on products or components that I have never tried.
If you have actual experience of quality valve and s/s gear fine then your opinion is as valid as mine.
If the measurements show there won't be an audible difference, so will listening tests when appropriate controls are used. Personal abilities or preferences aren't really relevant, if the basic claims made can't be supported with actual evidence.
Many believe in miracle spring water and homeopathy as well.
Well, since proving a negative isn't possible, we are left with those who make the unlikely claims to provide the evidence.
Can you prove I can't jump 20' high? I can, but I refuse to demonstrate it. I guess we are at a loss.
Unfortunately, neither side can "prove" anything, because human hearing is tied expressedly (and knowingly) to the indivual person "hearing" something
On my website, you'll find some pretty comprehensive measurements of fashion caps versus cheap Radio Shack parts.Siy the Russian Caps were as as cheap as chips. There was an excellent thread on diyaudio all about these Russian mil/spec caps. Like a lot of others I was skeptical about this thread started by a London based medic who had shelled out plenty for exotic expensive western made caps and then found these.
So I bought some and tried them. I was really pissed off because just prior to these I had been persuaded by my Dutch friend Harry to spend plenty for some hand made Dutch silver foil caps. Those silver foil caps were good but the Russian caps were like the Vishay Z foils - transparent.
So no one could describe the mil/spec caps as exotic and the Z foils have superb operating specs. You hav'nt tried either so your opinion is based on unproven bias which is not scientific.
On that thread it got polluted by a few narcissists who knew they were 'no good' but had never tried them and that all those who had tried them were fools and worse. I never comment on products or components that I have never tried. Describing mil/spec caps as 'fashion stuff' is really stupid, they were ludicrously cheap to buy, you sound like one of those American bible thumpers - only you have the truth - very unscientific.
And you know this how, exactly?You hav'nt tried either
Before going down that road, you might check the Acknowledgements section of Morgan Jones's "Valve Amplifiers," 4th edition.If you have actual experience of quality valve
