Aaronb1138
Get 2 and have a 4.2 setup.... Or a Fosi V3 and BT30D Pro for a 4.1.Can I connect a passive speaker (to be used as center) to the passive subwoofer output terminal? Can I still hook up my active sub using the pre-out if I do this? I am trying to create a 3.1 set-up using the BT-30D Pro amp. Thanks!!
But in all seriousness, what is your source? You need a multichannel AVR, multichannel decoder, or PC / RPi to get a true Center channel. Of those a PC is usually the best bang for the buck by way of NUC form factor stuff with high SNR audio codec hardware or external soundcards.
