Isn't the tilt supposed to be better though?115 db... destroying a masterpiece. Solderdude can confirma that the measured lacking in high mids is not audible because of the tilted drivers.
The sound from angled drivers is perceived more forward in the zone of the recession. For a better explanation @solderdude is the manIsn't the tilt supposed to be better though?
I'm referring to the hd560s findings where you fill the measured recession in the 4.5 khz region because it's not perceived like that. As you know I always found your discoveries to be agreeable. Do you think that the focal clear also have the same properties?It is called pinna gain and varies between individuals (pinna shape) and is driver diameter, angle and distance dependent.
As there is a slight 'boost' in the 1-2kHz range the Focals (the older ones at least) sounds very 'dynamic' and open.
This slight elevation, however, is just below of the frequency range where pinna gain starts to matter (for headphones).
Not everyone prefers metal domes though and find some Focals have an unnatural 'metallic' ring to cymbals etc.
A bit more than some other headphones. Some prefer that some don't.
Anyway Bow_Wazoo seems to like that.
Thanks for bringing this to our attention I see what Solder is saying as well.115 db... destroying a masterpiece. Solderdude can confirma that the measured lacking in high mids is not audible because of the tilted drivers.
I’ll tell you I whole heartedly love the og clears, I don’t care what they measure.
Not too far off and I know they probably don’t have equal measurements. But the 109 pro does give those og vibes. The presentation is fairly similar or the traits. Whatever the proper terms maybe.They sound very good and measure well. Price and driver quality always kept me from buying one though.
Mine will be delivered tomorrow. I felt in love with their sound in a shop in Athens but there was no stock and I ordered a pair from Supersonido in Barcelona. I payed 900 euro and I hope my impression will be confirmed over time. I cannot waitThey sound very good and measure well. Price and driver quality always kept me from buying one though.
Original. I was serching a direct hd600 upgradeVersion 2 or the original clear ?
The newer version doesn't have the clarity (sounds less clear) than the original one.
I have the Clear OG and HD600. Not a direct upgrade at all. The Clears have some peaky highs that are completely absent on the HD600's. I find them fatiguing after a couple of hours.Original. I was serching a direct hd600 upgrade
My unfortunately very short experience with the original Clears was very similar (I also own the HD600), really liked their tuning with a little peak around 1,x kHz which reminds me of many STAX models and them not having the Harman target bass bost.After the first two minutes of panic I can say that these are the best for my taste. The smoothness of the mids, and the metallic flavour of the highs, with the wonderful, agile and extended bass are qualities that I love. After 170 models owned and all the rest tried, i can say that the search is over. I hate the harman curve, because the bass is too much and the mids are shouty and too much upfront. I like the 1khz to be pronounced, like the airpods pro 2, and a little hole in the 2 khz region makes the mids a little more smooth with the illusion of space. Wow. The peaks in the highs make the metallic sound a little... metallic. A crash in real life must sound aggressive, and with my listenig level the added shimmer is welcome. My reference is the hd600, but the new flavour is a more joyful and musical experience
Why short?My unfortunately very short experience with the original Clears was very similar (I also own the HD600), really liked their tuning with a little peak around 1,x kHz which reminds me of many STAX models and them not having the Harman target bass bost.
Simply as they weren't mine, I nowadays listen so rarely to music by headphones (as I prefer reproduction via loudspeakers) that such an investment doesn't make sense to me. If the time percentage would change though I would be tempted to buy them.Why short?
I just had a deja vu.equalizing these masterpieces to that horrible mess of frequencies called "harman curve" is a crime. the Clear is a refined piece of gear that allows the listener to enjoy music in a very unique way, made of never forced details, agile bass, upfront yet cohesive mids, capable of incredible transients, but with a quality that remains liquid and grainless. How is it reasonable asking to them to play bassy music at 104 db? I listen music at 77 db with rare, short moments of 85 db. Real voices must be twangy and penetrant, metallic sounds must be rendered properly: have you listened to a crash from a drumkit? The soundstage is not the largest, but it's incredibly deep and layered. Please make a real life test; destroying one of the best headphone ever let them clip doesn't make them worse than a planar that doesn't distort at 104 db but lacks the wonderful dynamics and impact the French pair have.
