- Joined
- Jun 5, 2020
- Messages
- 4,808
- Likes
- 3,749
More images of the mysterious light walnut veneer:
In the first picture; it is.Unless that's supposed to be a discontinued 905?
Must be an old one, none of the 906s I've seen have that wall mount on the back.
Yep, definitely 905s.In the first picture; it is.
This picture is from Son-Video "review" of the 906s back in 2015. I strongly think this finish is discontinued for years.
Wondering if anyone else also experienced this: I’ve owned the Focal Aria 926’s for a few weeks now and despite a -3db treble reduction (via three band EQ), I’m still finding them painfully fatiguing to my ears. Unfortunately the mid treble also sounds a bit recessed in this case (they sound simultaneously dark in terms of low and mid treble and bright in terms of the upper treble), so I think it must still be the rising response after 7khz that gets to me over time, which perhaps is an area where most people just no longer have any hearing remaining (I can hear 17.5kz, and for example those “teenager repellent” tone generators are extremely painful to my ears).
Also, I have noticed that if I turn my head around 180 degrees or block the direct sound to the speakers, the fatiguing harshness mostly goes away, which I assume is related to walls being more absorptive of the higher frequencies. But even then, the harshness does not 100% go away, only maybe 50-90% gone.
Can you name a few songs showing the issue?Wondering if anyone else also experienced this: I’ve owned the Focal Aria 926’s for a few weeks now and despite a -3db treble reduction (via three band EQ), I’m still finding them painfully fatiguing to my ears. Unfortunately the mid treble also sounds a bit recessed in this case (they sound simultaneously dark in terms of low and mid treble and bright in terms of the upper treble), so I think it must still be the rising response after 7khz that gets to me over time, which perhaps is an area where most people just no longer have any hearing remaining (I can hear 17.5kz, and for example those “teenager repellent” tone generators are extremely painful to my ears).
Just about everything and anything with any content above 10khz at all. The 'airy' aspect of voices, instruments, etc. is just really boosted, or something... all I can say is that I get a feeling of discomfort/pain after I've been listening for a few hours. I can still hear it when I first start listening, but it's so subtle and not necessarily painful until listening for a while when my ears start getting fatigued. I'll try to find some though this evening.Can you name a few songs showing the issue?
I definitely do have a higher pain sensitivity to treble across the spectrum. I honestly don't know why though, because I can turn my favorite speakers (Genelec 8351B / Salon2's) up to extreme loudness overall, and don't feel pain/fatigue -- and surely at that point, there must be 10-20khz sounds at least as loud as when I play these at lower levels? So I'm not sure why treble tones would only be painful/fatiguing to me when not masked by a balanced response on the rest of the spectrum, but that does seem to be the case.I don't get any fatigue with my 906's, with a similar rising response. I'm nearing my 30s, but can still quite clearly hear that mosquito tone (which is grating as hell). You just must have an extreme sensitivity to it, I guess.
Yeah it's really interesting... I don't quite understand why, but my ears have what seems like unreasonable pain/fatiguing response to any sort of elevated treble frequencies vs the rest of the spectrum, even on frequencies that are already rolling off to my hearing. Perhaps related to tinnitus and chronic ear infections when I was younger? I don't know.I'm using the Chora 806 - which has a very similar treble response -- as my daily driver again and have personally never noticed that. I'm 29 and I can still hear 20kHz with a bit of extra volume and can hear 19 kHz without an issue.
Have you tried simply changing the toe-in? The treble drop-off above 10kHz is super steep off axis so at 30 degrees it should no longer bother you.
That said, I expect it's specifically the 6kHz to 10kHz region that bothers you. Most speakers will drop off rapidly past 6kHz (or drop off smoothly with large waveguides) while the Focals maintain a lot of energy up to 10kHz. The region from 6-10kHz is what makes the Focal's special and sound especially expansive, but it's also what makes them bright to some people.
Here's the EQ I apply to my Aria 906. I can't really hear the difference, to be honest.Just about everything and anything with any content above 10khz at all. The 'airy' aspect of voices, instruments, etc. is just really boosted, or something... all I can say is that I get a feeling of discomfort/pain after I've been listening for a few hours. I can still hear it when I first start listening, but it's so subtle and not necessarily painful until listening for a while when my ears start getting fatigued. I'll try to find some though this evening.
I'm using Sonos Amp with digital streaming sources like Tidal/Spotify/Airplay. Not sure if this has any problems like that.@echopraxia, any chance your DAC for Focal 926 system is upsampling without any smart SOX SRC filter so that you run audio at lower rates without native reconstruction filter and open for the digital image to pass downstream.
Most players for audiophiles can be set to exclusive use so native rates of the track material will be commanded to DAC chip for whatever track, but as you not sure then try shift one Revel or Genelec to problem system or vice versa.I'm using Sonos Amp with digital streaming sources like Tidal/Spotify/Airplay. Not sure if this has any problems like that.
My past experience with a tone sweep was similar. I could hear to 18.1 kHz with a lot of gain, however after that, no amount of gain did anything. That was on the Mackie MR624s. I should try it on my S400s since the smaller tweeter doesn't give up until much higher. I don't expect a different result, by I want to rule out speaker rolloff.I definitely do have a higher pain sensitivity to treble across the spectrum. I honestly don't know why though, because I can turn my favorite speakers (Genelec 8351B / Salon2's) up to extreme loudness overall, and don't feel pain/fatigue -- and surely at that point, there must be 10-20khz sounds at least as loud as when I play these at lower levels? So I'm not sure why treble tones would only be painful/fatiguing to me when not masked by a balanced response on the rest of the spectrum, but that does seem to be the case.
BTW I'm curious, if you try this tone generator, where does your hearing start to roll off? For me, the loudness does not start to roll off at all until after 14khz. Then after 14khz it rolls off pretty quickly until after 17khz or so, after which I can't really hear it at all. However, if I do turn my volume up 10db or so I do hear 17khz, and very painfully so. That does align with that I see here from the Focal Aria's on-axis response:
Did you ever manage to EQ the 10-15 kHz region and like these speakers?Wondering if anyone else also experienced this: I’ve owned the Focal Aria 926’s for a few weeks now and despite a -3db treble reduction (via three band EQ), I’m still finding them painfully fatiguing to my ears. Unfortunately the mid treble also sounds a bit recessed in this case (they sound simultaneously dark in terms of low and mid treble and bright in terms of the upper treble), so I think it must still be the rising response after 7khz that gets to me over time, which perhaps is an area where most people just no longer have any hearing remaining (I can hear 17.5kz, and for example those “teenager repellent” tone generators are extremely painful to my ears).
