- Joined
- Oct 25, 2019
- Messages
- 11,112
- Likes
- 14,777
Yes, but the OP seems to be suggesting a headphone should measure *actual* fiat. Not perceptually flat /neutral.well, it definitely has a visual mountain that centers roughly around 4khz. But most headphones ootb also roughly follow that same curve above about 500hz or so. If you go through the reviews and look at Amir's EQ adjustments to HC the alterations made at the high end are all over the place. There's boosts and cuts but I don't really see anything that looks like a constant 4khz boost. Otoh if you look below say 200hz a bass boost of some sort is almost universally applied...
