Hi,
I read a lot about amps should just be wire with gain anything else is a effects box yet the same isn't applied to headphones/speakers/IEMs. Shouldn't they (speakers/headphones/IEMs) replay back the signal without adulteration? Why isn't effect box sneer applied to the Harman target. If you had an amp that amplified the sound into Harman target and speakers/headphones that were flat you would end up at the same place.
Thanks
Haider
Thanks
Haider
