Going through recommendations found through this Q&A and skimming through here I'm looking at the Peachtree amp500 $1,499.00 or 70usd/month @0apr and the Klipsch RP-8000F $830 or 70usd/month @0apr. I haven't found the right DAC yet but I'm leaning to
https://www.inno-maker.com/product/skylarkii-dac5122bt/ at 80usd which promotes ample rates up to 384-KHz/32-Bit. At 80 bucks I can use it as a streamer till I can upgrade to a good all-rounder in the future. 140usd/month+80usd is 100% do-able.
edit: the DYI Raspberry Pi DAC is still on the table just a bit more than this Skylarkii dac. at ~130-190usd the Raspberry pie is a next upgrade I think
Do you have the opportunity to listen to some Klipsch RP-8000F before you buy them? At any hifi dealer where you can also compare with other speakers? For many, Klipsch is a water divider. Some love them others think they have too sharp a treble. In what category you belong to, well. Who knows.
What else have you heard about the brand / model speaker? Which ones did you like? Which ones did you not like? You know if you like brand / model X, it is possible that you like, or do not like the Klipsch RP-8000F. In any case, it gives an indication.
Just to show how different it can be. Last year I bought a couple of used ones:
FOCAL-JMLAB ELECTRA 905
www.hifi-review.com
In the reviews they write:
The bass is tight and well controlled, driving on with a measure of power and authority rare in a stand-mount, if a little constrained in air and freedom, and inevitably lacking in bottom octave weight. And if the treble is slightly obvious, it's also notably sweet and clean.
I really disliked them, lack of bass (I tested with different amplifiers). Treble
sweet and clean. Nop in my ears too much, too intrusive.
Sold them. The buyer was extremely pleased and thought that they sounded so much better than the Dali 850 he had. Incidentally, a Dali model I heard that I think sounds much better than 905. So it can be.
Conclusion. Listen and test yourself.
Edit:
By the way, when I think about it. The Dali 850 might be for you. If you can imagine buying used. They like effect so Behringer A800 suits them well.
www.dali-speakers.com
There are many fun speakers to choose from.
In addition, if there is only the potential in the speakers (low distortion), you can always sharpen / straighten the frequency curve later using EQ.
Something I might have done with those Focal 905, but I did not think of that then.
Incidentally EQ is something that is more the rule than the exception to do with the subwoffer (regardless of price / size)
