Fiio K11 R2R vs. SMSL DO100 Pro?
olds1959special
Los Angeles, CA
I currently use an SMSL DO100 Pro as my DAC and am thinking of adding a Fiio K11 R2R specifically for music. I recently tried a turntable in my system and enjoyed the sound of vinyl. I'm hoping an R2R DAC will get me closer to that presentation. I'm having a little trouble with my DAC sounding bright, although the "linear phase slow filter" seems to be helping with that. I love the DO100 Pro because it has a remote. The K11 R2R does not, but also has a volume control. So I thought having to get up to turn down the music is a compromise I'm willing to make if it improves the sound quality or offers a warmer sound alternative. (My pre-amp has dual mono volume controls which are not convenient to use.) I think I can also daisy chain the two DAC's via the coaxial output/input and use them that way if needed. OTOH, I think maybe I don't need this. I am listening to the SMSL DO100 Pro now and found the FL6 setting "linear phase slow filter" to be significantly less fatiguing than FL4, "linear phase fast filter". Maybe this is all I need? Or will the R2R Dac offer something special that I want? I listen to a lot of vintage music, also acoustic, vocal music, and jazz.
Check out Archimago's measurements and demo recordings of the Cayin RU6 R2R thumb drive DAC:
That should give you a pretty good idea of what to expect from the K11 R2R.
Despite the very different form factors, both have a similarly performing R2R implementation with around 60-70dB SINAD.
The only way to daisy chain the two is to do USB/Toslink->K11->Coax->DO100 Pro.
This would bypass the K11's R2R DAC and use the DO100 Pro's DAC for conversion to Analog.
I listened to the sound clips and liked the sound of the NOS, so I ordered the K11 R2R to try out. I will share my results when I am listening to it. I’m going to send the digital coaxial out to my DO100 Pro, so I can use both without unplugging anything. Hopefully it will display the sample rate on both units.
got the K11 (non R2R) and very pleased with it. I see there is still no review on ASR
I got the Fiio K11 R2R Dac and am listening to it now. I'm playing a Diana Krall record in NOS mode, and immediately noticing the change of sound coming from my SMSL DO100 Pro. There's a little more weight to the sound in the midrange and bass, a little more texture. The sound is not as strong and clear but rather slightly diffused and muted, but not in a bad way. It seems relaxed, dry with a more natural tonality, slightly more compact in soundstage, unlike the DO100 Pro which has a kind of a hollow/big/open quality that sometimes feels artificial, or too "wet". I know subjective descriptions don’t mean much but I tried to describe what I’m hearing. I wish it had a remote control for the volume. It seems only some very expensive R2R dacs have a remote with volume control. (Halo Spring 3 looks like) I thought of adding a Schiit Saga in passive mode (it has a remote) in between the DAC and pre-amp but I imagine this would not help the sound.
I also have daisy chained the DAC's and they match sample rates on the display. I am able to go back and forth between inputs and compare the sound coming from the same USB source (going into coax in the DO100 Pro). The DO100 Pro seems a bit hotter as when its at 55 or so it sounds like 70 on the Fiio, which is strange because I thought the K11 R2R actually had a slightly higher output of 2.7v vs 2.5v. More tests soon to come and I will post my comments on the sound differences when I can listen louder (early in the morning now.)
I am starting to wonder if there is any value to the Fiio R2R dac in my system. It has no remote, making it a pain to adjust volume. It also clearly does not sound as good overall as my DO100 Pro, maybe it's the SINAD level I'm noticing, it feels smaller, compressed. It definitely adds a warm flavor and a unique tonality, but in the end I wonder if I'm really paying attention to or needing this. I seem to have found a good filter option for the DO 100 Pro for music, minimum phase fast, which seems to keep it from sounding bright (linear phase fast sounds brighter I think?). Additionally, my vintage pre-amp has a little crosstalk between inputs, so when I daisy chain the DAC's and use them together without turning one down, I get unneeded noise.
I'm going to move the R2R dac to my other system that doesn't need a remote.
After using both the Fiio K11 R2R and SMSL DL200 (similar to D0100 Pro) in my Elac bookshelf speaker system, I would like to write down some thoughts. The Fiio K11 R2R is really fun to listen to at first but seems to be a bit dead in terms of harmonics in the sound. I am using it with my MG Head OTL tube headphone amp and Beyer Dynamic DT990 - 600 ohm headphones, because the headphones are so bright, it balances things out. But for anything else, I prefer the SMSL DL200 (or D0100 Pro) for its more natural treble and presentation of harmonics in the sound. They are more smooth while the Fiio K11 R2R is more punchy. I have owned (and returned) a Fiio K7 which seemed similar, warm in tone quality but a bit dead, so I'm wondering if this is a Fiio house sound thing.
Right now I'm using the SMSL DL200 instead of the K11 R2R in my system. I gave up on the K11 R2R and am returning it. It doesn't sound natural, especially in the high frequencies, and it's even worse in NOS mode.
Picked one up to see what all the fuss was about. It's not horrible for the money, but it does some things that my ears don't like. Heard a bunch of harsh pronounced sibilance during a few tracks (Mr Brightside by the Killers as an example) where I don't hear it on my other DAC/headphone amp and not in my 2ch setups. Whether it's the logic or analog output section, it's there. I heard this with OS and NOS modes. I was hoping for a bit more in the bitrate dept, but even with ASIO it doesn't accept anything higher than 98khz (so no HQPlayer shenanigans with this thing).
My take away is it's fine for the average listener, sounds a little more relaxed and fuller than it's non R2R counterpart. I don't think average listeners would be commiting any fouls by not going any further than this. I also don't spend a bunch of time auditioning DACs, so not sure what really sounds natural at this price point. Honestly, not natural was one of the things that jumped out at me, but I can hear why someone would like the sound. Sibilance is a flat no for me, so that's my biggest issue.
I'm hearing what sounds like exaggeration in the bass and midrange area which makes the instruments sound a bit bloated and unnatural. Similar to hitting the Loudness button on your old amp. It also gets a bit fatiguing after a while, especially with headphones. This is in NOS or OS modes.
Compared to what? And how ?
Oh sorry. I use Qobuz through the a WiiM Pro via coax out. I only have the Wiim Pro and Pontus II DACs to compare with but I haven't compared it with either. I was just stating how I think it sounds on its own.
Using Arya Stealth headphones or Linton Speakers via a Vincent SV-500 amp.
i tried the Fito K11 r2r and found it real uncomfortable to use, the unit is lighter than my Cables, and as it has no remote, i had to push the knob often,
and the Dac moved and shaked. And while the sound was nice at first trial, it could not handle complicated music very well, it did start to sound unengaged
then for the dynamic parts, for example the soundtrack to "The Book of Boba Fett" was rather bad, my 12 years old CS4398 Dac did transfer that much better.
It did get better with the "OS" mode, but there it was cleaner, but other soundstage, and also not very dynamic, maybe the power supply is part of the problem?
I did send it back, at the moment i use a AKM4493 built in the Aiyima DP02, it is real better for my needs, it has a remote, XLR outs, and sounds always ok, not so changing
with the genre of music.
I almost bought the K11 R2R because it would allow use of my 12V linear PSU. Instead I went with the Fosi ZD3 which is also 12V, comes with a remote, has an HDMI connection and cost slightly less. I don't need another headphone amp as I'm very happy with the Topping DX3 Pro+ driving the Edition XS. The Astron linear regulated PS ( lower left ) took the Fosi SQ to another level and I think it might do the same for the K11 R2R.
So the LPS you are claiming it enhanced the SQ? How exactly?
Increased clarity, detail retrieval with a darker background.
Wasn't a test done on this forum that showed zero improvements?
PS
Yep
PS
Yep
Not with my gear, my mods, my listening space, and my ears.
