Extreme Snake Oil
symphara
@symphara Hi, he answered me:
"I did a quick skim without getting into the math. Well, interesting. But this only proves that a large amount of superimposed interference produces harmonics. Well, if the signals are summed up, the signal becomes more rectangular. And the rectangle is 100% THD."
Your original text said:
"if we mix two over-acoustic frequencies f1 - 1001000 Hz and f2 - 1000000Hz, we get the sum of these two frequencies f1+f2=2001000"
I don't know what that means. This is not how sinusoids "mix". 2Hz + 3Hz sinusoids don't produce a 5Hz one. We don't "get the sum of these two frequencies". They produce a more complex function, which depends on the frequency, amplitude and phase of the components.
Adi777
@symphara Different person answered:
"This refers to the time domain. In the frequency domain, there will be these components, their harmonics, as well as intermodulation fringes. (in the case of a non-linear system)
In the time domain, e.g. sin(2x) + sin(3x) there will be such a signal. (it's not in Hz, but the principle is the same)
In the frequency domain, there will be 2x and 3x fringes, in the case of non-linear systems, also additional fringes.
But what does this have to do with cables?"
Links author first comments and he make a cables:
Adi777
Of course I know that you can be little tired to answer ;)
"By deductive reasoning, we can speculate that the notes tuned to A432
they harmonize directly with nature and the cosmos."
Lol
symphara
It has nothing to do with cables.
I hope you don't take it the wrong way - to me it looks like you're being subjected to the "Dopeler effect", i.e. you're being bamboozled with complicated sounding stuff coming at you fast, in the hope that you'll dope out and buy into some stupid idea.
In this case, that there's something magical about cables in the audio domain. There just isn't.
fpitas
Northern Virginia, USA
Lol
Uh...I think that's a clear clue that they are spinning a yarn.
Adi777
No, no, no, definitely no. I don't have experience with cables, but I am definitely closer to being a skeptic in this regard ;)
Nature and cosmos xD :facepalm:
fpitas
I'll reiterate: properly working cables do not make sum and difference frequencies. End of story. If they say that happens, they made that up.
doitttt
Palladium
Wait, what? Isn't this just a pretty power outlet cover?
DonR
Vancouver(ish)
One of the comments in that thread says "it makes a measurable difference"... I bet it doesn't.
Palladium
You would think turning a LED light on elsewhere in the house would have more effect than something that doesn't even have a load across the live and neutral pins, even in the realm of incredibly far-fetched plausibility.
S
Spkrdctr
These are probably money laundering schemes for drug money. They essentially pay themselves, and function as a piggy bank.
If the business doesn't make sense, and it continues to exist despite the obvious problems, it's probably money laundering.
You are probably right.
BeeKay
EU
Why bother with hardware if can have the same doing "consulting”? ;)
doitttt
all power filters and cables.
there should be law, says a high-end manufacturer. can only charge so much for their products.
just take nordost cabler.
to 28,553 dollars for 2.5 meters.
Nordost Odin 2 Power.
snakeoil one must say
YesChickenNuggets
You have to have both, the goal is to look legitimate, withstand scrutiny with multiple camouflage angles while maintaining a distance of ownership of several SEMI-empty shells for plausible deniability.
