Experience with Pro Cinema Speakers in a Hifi setup?
SCR
Berlin, Germany
While looking at the range of JBL Pro Cinema speakers i wondered how cinema speaker setups such as the 3678 or 4722/4722N would perform/measure in a two channel music listening context. I would guess that the horn designs are optimized for a bit of distance given a typical cinema setup, and that the treble output needs to be a tad higher due to the filter effect of the cinema screen in front of the speakers. The idea of combining such a setup with a Hypex FusionAmp sounds attractive though, maybe even as a cheaper alternative to a JBL 4430/4435 type speaker?
Did anyone has tried out and measure such setups? I guess that there must be a reason those are not discussed in a hifi/music setup?
Reactions: CMB
At least some of those look like good candidates for judicious EQ.
Did anyone try to set up a pair with a plate amplifier with active crossovet, any insights?
me.
I had that jbl 2384 horn with 2435hpl compression driver.
Active crossed at 750hz 24db LR to double 15 (eminence magnum 15lf).
I would spin eq up to 1khz when going for "flattening" levels.
Yup, took a bunch of eq (slight cd eq boost in crossover), but was very loud, clean, and dynamic.
I did not find that the horn boosted the highs, you can see measurements on the asr thread.
Double 15" running 30-750hz really beats you up at 15' away.
The horn only kept its vertical dispersion pattern down to 2khz, and 2' wide horn did its best to control down to 750hz.
No measurements of course.
10 band eq worked wonders as I usually listened under 90db..................
