Eversolo DMP-A6 Streamer @Purité Audio
@Brian Hall
Thanks for the reply.
In terms of performance I imagine they are similar (Eversolo 6 also has a good Dac) considering that I will probably use the Dac of the Rega Elicit MK5 amplifier
All that remains is to understand what the Eversolo remote control can do.
So if it turns on/off, has a mute button, and can change radio channels (even just free internet radios) I think I'll get Eversolo.
I don't care about room correction because it can never be at the levels of the Dirca which uses Nad with a dedicated microphone... it seems like an almost useless accessory if tied to the microphone of the Apple smartphone!
Does Eversolo also have an equalizer?
A thousand thanks.
Yes software upgrade included an equilizer. In general I am extraordinarily pleased with my eversolo. I do only use the digital out, but the things interface is nicely done and it has a lot of features
@Purité Audio
I also used it on Wiim Pro Plus, excellent.
Do you know if it also has normal equalizer?
Do you know anything about the functions of the remote control?
Basically it should do: On/Of and Volume/Mute... but does it change channels? that is, if I turn it on I can recall the stored preset stations (even a small number).
A thousand thanks.
@shion_ca
Thank you very much, we will answer together -:)
All that remains to be understood is what the remote control does, if it can free me from the smartphone for the basic functions I asked for it would be perfect!
See you soon.
On/off, input selection, mute, volume, turn display on/off change the function of the screen, some playback options.
EQ on the digital outputs and rca/xlr.
@Purité Audio
Dear, thank you very much!
Practically everything except changing the station channel which I would necessarily have to do from the application exactly?
Look, if I turn it off, when I turn it back on, it keeps the last selected station in memory (already something).
Thanks again for your availability.
Everything can be controlled via the app of course.
