Equalizer APO Question
phoenixsong
Hi All,
I'm new to Equalizer APO, and can't figure out why it is showing a bass boost peaking at 20Hz when the Equalizer is turned off. Also, for No. 3 regarding processing stage selection, should I select pre-mix or post-mix for the playback?
Katji
It depends how you got to that.
example.txt boosts at 20 and 45 and then the GEQ reduces it.
P
phoenixsong
Yeah you're right, I deleted the example text and it leveled itself out
