Equalizer APO/Peace
Clintosity
Hi guys, I've installed equalizer APO and peace to try some EQ's but as soon as I install equalizer APO even without peace or with peace installed and eq's turned off it sounds like the sound is coming through a radio, like the sound just goes very thin. I've checked and the bitrate is ok/audio enhancements are off and increasing the volume doesn't help. As soon as uninstall equalizer APO it sounds like the sound has body again.
Are you using an external DAC, or the internal audio of your laptop/PC?
Hmm, not sure what could cause this, sorry.
Hi, are you on win 10?
You can try Troubleshooting options and install APO as SFX
