Why would that be? The output impedance has to be functional the output device’s and topology not not the transformer. Care to explain?Power amps with a toroidal mains power supply have a lower output impedance.
I can vaguely see why because the PS secondary is in series with the output transistors but there are so many other things going on .... How much effect does the mains transformer really have?Power amps with a toroidal mains power supply have a lower output impedance.
Output impedance depends more on the capacity of the power supply caps than the transformer.Power amps with a toroidal mains power supply have a lower output impedance.
2. EI Core has lower coupling capacitance between primary & secondary, so it blocks high frequency common mode noise from main AC far better than toroidal transformer
Toroidal is expensive so they work at max possible flux (they saturate easily by over voltage). With correct design EI lamination is better and easy to repair, and the core is naturally grounded. No real advantage for typical audio application.
http://www.soundstagenetwork.com/maxdb/maxdb071998.htm
EI transformers have much lower in rush current on start up so you dont need "soft start" circuits for large VA transformers which saves a lot of trouble especially for DIY. These "soft start" circuits all have some potential safety / reliability issues.
I am talking about " in rush current" when you first switch on an amp. Large torroids draw huge current and require "soft start" circuit to mitigate this. EI dont have this issue.No. This is only true if you are pushing the transformer past saturation which you should never be. < Saturation it comes down to inductance mainly.
Also, I'm pretty sure the McIntosh solid state amps don't use toroids, either.
McIntosh amps don't need to use toroidal transformers due to their usage of blue VU meters.
Yep. Better for impedance matching, too. https://www.manualsdir.com/manuals/117061/mcintosh-mc1201.html?page=14I think most tube amps use EI transformers? Or at least some other non-toroidal kind.
Marketing is everything, the machine to make coils on a toroid is expensive, with good marketing "low noise" "low losses" etc the price of toroidal transformers is "competitive". Nobody selling toroidal transformers gonna tell they can go easily in saturation, tend to work hot, have more in rush current....marketing could make this issues irrelevant to non technical peopleI thought @levimax said this point about price is no longer true.
For DIY Antec torroids are cheap and they have a huge number to chose from and they are in stock. It is hard to even find large EI transformers for power amps for DIY. Maybe it is different for the commercial OEM market but I doubt it... The volume has gone to torroids. My understanding is that Antec has high speed automated equiptment and can really crank out torroids. All they really are is wire wound in a pattern..no cores, brackets, etc. so with the right equiptment they are cheap to make.If you're buying OEM parts, the price from the maker is your BOM price. His cost of production doesn't matter to you.
And @levimax seems to be saying that toroids are cheaper parts to buy now, unless I'm misunderstanding.
But doesn't mean toroidals are better, used at high magnetic density (necessary for competitive price) in power supply applications with poor mains regulation they simply are a nightmare...add that to the BOM and reliability of the design (transformer thermal issues, short insulation life, unexpected repetitive blown fuses) or worse as forced use of slow blow fuses in electronics!.If you're buying OEM parts, the price from the maker is your BOM price. His cost of production doesn't matter to you.
