Jesus, at what volume do you listen to music or movies??? In most Western European living rooms it should be about 1-5 Watts simply to avoid your neighbors breaking your front door ;o)
I have 6 of these, 4 running bridged mode (4 OHMs) into 4 Dahlquist M-905's, 2 running stereo mode (2 OHMs) powering 4 semi custom (dual 4 OHM [custom wiring makes them 2 OHM]) voice coil 12" Pioneer Automotive Competition SUBS.
This is the results of the one that Amirm tested (all have been resto-modded (upgraded without changing the circuit design) by Peter at
QuirkAudio:
So, The answer is: if I am in my yard, or in my house, whatever volume that I want:
EDIT: adding Lab Input Measurements
I was surprised that the frequency response was not flat but was relieved to see later in the thread that this is due to insertion of low and high pass filters. So here is the frequency response with Lab input that doesn't have such a filter:
Response now (in green) as it should be, ruler flat to below 10 Hz, and well extending past the 40 kHz limit of this measurement.
I figured the filters may be adding some noise/distortion so re-ran the dashboard again:
Distortion doesn't change but if you look at the noise floor at 20 Hz, it is down by some 10 dB. That improves SINAD a couple of dBs, making the amplifier stand out even more!
Zoomed:
And signal to noise ratio:
Nice to see innovation like this from equipment that is over 30 years old! Shame on manufacturers that produce amplifiers for much less power, more distortion and higher prices these days. No, you don't get a fancy case here and sheet metal is strictly budget category. But you are not going to sit on the amp. The guts are where it matters and NAD 2200 delivers.
NOTE: the output relay on stock 2200 gets corroded and fails over time. There are videos and DIY threads on how to upgrade the relay there to fix the problem. The unit tested here has that fix. Other than that, there are not reports of many other reliability issues even though NAD products are often said to be less reliable than other brands.
Overall,
I am happy to recommend the NAD 2200. I almost gave it the highest honors but given the upgraded nature of the test unit, and the fact that used amps may have issues, I avoided that. But you could have easily pushed me to give it the golfing panther.
