Some bold claims by Avangarde regarding horn speakers:
• 8 x times higher dynamic bandwidth
• 90% less distortions
• 10 x times more details
I hesitate to comment being a "horn guy" for much of my life but yet I must.
First about moving mass, it is hard for many to grasp that it is moving mass that makes an acoustically small radiator (where the radiator is less than K=1 in dimension) have "flat response". To be "flat" it MUST follow an acceleration response (where the velocity falls with increasing F) !.
With an acceleration controlled response, the excursion increases by a factor of four, for each octave you go down in frequency.
This also means that if one attaches an additional mass (say doubling the total mass) to the voice coil of a driver, the sensitivity and free air resonance is lowered BUT the HF corner is unchanged!
It might be confusing here because a "big heavy" woofer rolls off up high but that is primarily because that woofer has much more electrical inductance (due to it's larger voice coil) which IS an electrical roll off.
A proper horn on the other hand feels the radiation resistance and the horn mouth typically greater than K=-1 in it's operating range (an exception would be a bass horn where the mouth may be less than K=1 in the bottom of it's F range.)
Driving a resistance to get flat response one needs a Velocity response which means that the excursion doubles (instead of 4x) for each octave you go down an octave in frequency.
As opposed to the direct radiator, the moving mass DOES roll off the power response at the high end and so horn drivers normally have a much stronger motor for the area of the radiator and the voice coil inductance IS also a roll off AND so is the acoustic low pass filter which is produced by the air volume between the radiator and the mass of the air in the throat so often one see's 3 separate roll off slopes at the high end of a horn response.
That acoustic power response roll off is often "disguised" by using a curved wall horn and in a perfect world, one can use the narrowing radiation angle to concentrate the energy on axis so that it compliments the power response roll off to maintain a more "Flat response" on axis. This why constant directivity horns require "CD compensation" as a constant radiation angle does not hide the driver's falling power response.
Fwiw, some years ago i was asked to write a chapter on loudspeakers in a book (below) where i tried to use plain English, analogies and examples to explain drivers, back EMF and some other aspects of loudspeakers.
If you can borrow a copy, this might be of interest to other cone heads.
Handbook for Sound Engineers (Audio Engineering Society Presents) [Ballou, Glen] on Amazon.com. *FREE* shipping on qualifying offers. Handbook for Sound Engineers (Audio Engineering Society Presents)
www.amazon.com
Lastly, a minor quibble is using an impulse response to infer something broad band. The impulse response visually shows the HF response's behavior and the lower one goes in Frequency, the less one can see anything indicative.
Best Regards
Tom Danley
