- Thread Starter
- #41
The best crosstalk would come from separate relays for the left and right channels. Beyond that its impossible to say which single relay would have lowest crosstalk. Reed relays won't necessarily be any better. You can lower crosstalk in several ways beyond the relays, such as lowering impedances, but overall its easier to use separate relays for L and R.
Right. Well, I'm even getting a bit of crosstalk on the second input when unswitched. Wondering if there is a better way to isolate that so that absolutely 0 comes through when it's not active. Granted, in practice I'll rarely have both of my sources on at the same time, so it might not really matter in the end.
As for isolating L and R channels, I haven't actually tested how bad that is, I'll take some measurements today or tomorrow. I did end up putting the PCB on nylon stand-offs, and will try using a 10 Ohm resistor for grounding one of these days to see how that measures. Do you think it makes sense to play around with even higher resistance for grounding?
