Vavilen
Hi guys!
Is the SMPS1200A700 the best option for Purifi modules? Or the SMPS3kA400 would be better?
I like to support Microaudio from this forumHi guys!
Looks interesting! Which module would you recommend?I like to support Microaudio from this forum
ask him, this depends on your target, how many channel to add in the same chassis etc. i have the very first version of the 1k smps, now it is already 3rd gen with nice improvementsLooks interesting! Which module would you recommend?
I have 2 x (Purifi + Neurchrome buffer) channels. Do I need 1 1k smps for each channel?ask him, this depends on your target, how many channel to add in the same chassis etc. i have the very first version of the 1k smps, now it is already 3rd gen with nice improvements
Interesting: last March I bought one EVAL2 kit also from Soundimports and it had occasional very loud "snap" sound from the connected speaker when powering up. It sounded very similar to what you get when you connect high DC voltage directly to tweeter...Hi guys
I want to share this experience with PURIFI technical support, as I wrote on this same thread a few weeks ago, my PURIFI Eval1 Kit has always had the problem of a frequent BUMP on power up (more than a BUMP it was a SHOT!) , I decided to write both to Soundimports support (from which I bought it) and directly to PURIFI, both suggested to send back the EVAL KIT for investigations.
PURIFI herself was very professional and suggested that I send the KIT directly to them, as soon as they received the KIT they repaired it in a few hours and sent it back.
Today I received it and after many tests I am convinced that the problem is actually solved!
I am very satisfied with PURIFI's product and support, I recommend it to everyone !!
Hi TimoInteresting: last March I bought one EVAL2 kit also from Soundimports and it had occasional very loud "snap" sound from the connected speaker when powering up. It sounded very similar to what you get when you connect high DC voltage directly to tweeter...
In November I finally contacted Purifi and sent the unit there and it was fixed in few hours. Sounds like they have released a bad patch of these amp modules. My older EVAL1 kit doesn't have this issue, only the normal very quiet "snap".
Did they tell you what they fixed? I asked, but got no reply. I didn't notice any changed parts. Maybe they just reprogrammed the controller chip on the vertical PCB?
Hi @starfly ! Could you please share what are the speakers protection plates do you use? And what is the grey signal cable? I'm also building my amp with Neurochrome buffers and cannot find the cable. Thanks!Sorry, a bit of a late reply Below a picture of my build from last year with Neurochrome buffer and speaker protection circuit. All still works great a year later. The 12 VDC power supply in the bottom right provides standby power to the Hypex SMPS1200A400, and the red relay board in the top right provides trigger functionality to my amp (I have 2 trigger inputs).
If I were to do it all over again I would probably create a little PCB to more cleanly distribute power to the two amp modules. Now it's an ugly hack job with splicing wires, but hey, it works! And with the cover on, no one is the wiser
Does anyone know how to QC a finished Purifi amp? For example, I can use a mic to measure a speaker. How to do this with an amp?
https://www.amazon.com/gp/product/B07SR3S2W3Hi @starfly ! Could you please share what are the speakers protection plates do you use? And what is the grey signal cable? I'm also building my amp with Neurochrome buffers and cannot find the cable. Thanks!
Thanks!
The gray ribbon cable you mean? That is connected to the SMPS. Don't remember what it does, I think just communication between amp modules and SMPS.Hi @starfly ! Could you please share what are the speakers protection plates do you use? And what is the grey signal cable? I'm also building my amp with Neurochrome buffers and cannot find the cable. Thanks!
It has 2 x10 pin connectors, which fit the Neurochrome buffer and Hypex SMPS.Thanks!
But I think, this cable doesn't fit my configuration. It has to be 3 x 7-pin connectors cable.
