- Thread Starter
- #1,681
Sorry to hear your problems here continue. It must be very frustrating. Just removing the face of S1 is no problem - mine ran fine after that, as did the one where I unsoldered it altogether. But there does need to be a working /AMPON signal on J3p1 of the EVAL1. And it must be in hardware control mode. The absence of VDR seems to be the top culprit at the moment. Why?It's still under warranty, and I'm sending it back to Hypex. Thanks for your help. It came back from one such warranty repair and didnt work just like the first time. My concern is that something else is causing the SMPS to fail. I have Ghent's wiring kit, so it will no longer be my wiring. I've requested and they've agreed to look at my wiring harnesses to see if they were (are) the root cause of this difficulty.
If' that's not the cause, then perhaps something went wrong with the Purifi. I will be reaching out to them in the next day or so. That's why I am concerned by the switch removal, though it involved nothing more than the process I described and not touching anything soldered.
My final concern is that the board practically touches the back plate, so I worry that could cause a short, though I've been assured there's nothing electrical near the board's back edges to come into contact with the back plate.
I suppose an active /FATAL from J3p3 of the EVAL1 to the SMPS could be an issue, as well.
